Chris Green Posted May 9, 2013 Posted May 9, 2013 (edited) As some of you may know, my engine needs to come out again, while I'm doing this, I want to increase the bore size. Question time 1) Has anyone done this before? 2) What is a safe increase in mm? 3) What pistons were used? 4) Any further cooling upgrades required? Thanks in advance Edited May 9, 2013 by chrisgreen1993 Quote
Jamie_VF22 Posted May 9, 2013 Posted May 9, 2013 (edited) Yes mate many people do it when they go forged engine Most people go for 74.5mm pal I use Wossner forged pistons mate Edited May 9, 2013 by Jamie_VF22 Quote
AdamB Posted May 9, 2013 Posted May 9, 2013 (edited) You can increase the bore size but you'll need to use oversized pistons. Ie forged pistons as Jamie said.There is a limit on how much you can hone the stock cylinders before a rebore to oversized pistons is needed but don't have it to hand atm.You won't need any cooling upgrades, but proper maintenence of the cooling system is paramount. Edit: The largest bore size you can go to without having to rebore to suit oversize is 74.030mm.The largest OEM piston size is 73.93mm. Edited May 9, 2013 by AdamB Quote
morgey Posted May 9, 2013 Posted May 9, 2013 (edited) Dont toyota do oversized pistons? Im sure they do for 4ages. :/ might have a quick google about...Yeah toyota do oversize pistons for 4age's so surely they would for 4e's? Edited May 9, 2013 by morgey Quote
russ78 Posted May 9, 2013 Posted May 9, 2013 for what you would pay for oversized Toyota pistons better off with forged ones for around the same price its a bit of a no brainer Quote
AdamB Posted May 9, 2013 Posted May 9, 2013 They do 3 sizes : Size 1 - 73.91mmSize 2 - 73.92mmSize 3- 73.93mm Quote
morgey Posted May 9, 2013 Posted May 9, 2013 (edited) True but i think he's running a 5efe, find some forged n/a pistons lol Edited May 9, 2013 by morgey Quote
morgey Posted May 9, 2013 Posted May 9, 2013 They do 3 sizes : Size 1 - 73.91mmSize 2 - 73.92mmSize 3- 73.93mmWhen i say oversize i mean 81mm stock an 81.5mm oversize. Like after a rebore piston. Do they not do this for 4efe's? Quote
morgey Posted May 9, 2013 Posted May 9, 2013 Not from toyota and not all that cheap buuuut....http://www.precisionintl.com/Stock.aspx?Code=PTO4E40202E&EID=4356 Oversized 4efe pistons. Measurements are in imperial 0.020" is .5mm you can also get 0.040" or 1mm oversized from there Quote
AdamB Posted May 9, 2013 Posted May 9, 2013 When i say oversize i mean 81mm stock an 81.5mm oversize. Like after a rebore piston. Do they not do this for 4efe's? Not OEM Toyota mate. Think them pistons are pretty cheap but, but I not sure I would trust them. Quote
Chris Green Posted May 9, 2013 Author Posted May 9, 2013 Thanks for the input guys. Ive hear of people using Vitara pistons 75.5mm. I couldn't go forged as that would lower the compression. Quote
morgey Posted May 9, 2013 Posted May 9, 2013 Vitara pistons are used on boosted engines as they handle it well. Also 75.5 is right on the limit of the block! Quote
AdamB Posted May 9, 2013 Posted May 9, 2013 I personally wouldn't opt to use that size piston. It wouldn't take much to buckle between the cylinders. Unless you spent a bit of money and ran a closed deck block to strengthen it. Quote
Taggy Posted May 9, 2013 Posted May 9, 2013 (edited) I think the point is why do you want to increase the bore size, is it because your bores are damaged already so you have to have a rebore to clean them up, or are you doing it just for a performance point of view? Only wanted to check as the HP difference will be virtually nothing if your bore the block out to its limit and put oversize pistons in, the actual displacement increase is so small your barely adding anything. Unless your engine needs its because its scored, i would save your money and just put the same size pistons back in, use your money on other areas will be much easier/cheaper to get more performance i.e a good tune/map . Someone did work it out before on TGTT, i think going to 75mm adds like 30cc or something with dished pistons lol its not much! Edited May 9, 2013 by Taggy Quote
Chris Green Posted May 10, 2013 Author Posted May 10, 2013 I haven't checked if the block needs re-bored, by the looks of things there isn't much point getting it rebored. I'll just re-hone the bores when doing the rings and spend the money else where. Thanks again for the input guys. Quote
