grimpigeon Posted May 15, 2013 Posted May 15, 2013 Hi there, I'm looking to do the conversion but I just had a thought... If I chuck the turbo'd engine in there, what would I have to do with the ignition as my guess is that the ecu won't be programmed to my ignition, but the ignition of the new engine. Any help is welcome as I'm a noob. Quote
Rob H@RCH Engineering Posted May 15, 2013 Posted May 15, 2013 you need to change the wiring harnesses and the ecu too, you can convert the wring harness from the n\a to work too but it takes a bit of doing but you will still need the ecu, if you modified the harness to fit its easier to use a ep82 ecu as there a 2 plug like the n\a loom. Quote
grimpigeon Posted May 15, 2013 Author Posted May 15, 2013 If I bought an engine with a wiring harness, would that be easier? Or would modifying the loom be easier? If so, is there any instructions on how to do so? (Sorry for the 21 questions) Quote
5e colin Posted May 15, 2013 Posted May 15, 2013 contact weejon on tggt he knows how to wire na loom to turbo but u still need 4efte ecu etc Quote
StuDoc 72 Posted May 15, 2013 Posted May 15, 2013 (edited) Id imagine re wiring an N/A loom to suit turbo would be difficult even for a seasoned pro. For a noob it will be near on impossible. Youd be better off with a turbo loom. Saying that unless your desperate to keep the N/A then you wuold be far cheaper selling up and buyin a turbo'd car. Will be far safer and more reliable will save you endless amounts of hassle. Edited May 15, 2013 by StuDoc 72 Quote
grimpigeon Posted May 15, 2013 Author Posted May 15, 2013 Would I be able to use te same key or would I have to get a new one? Quote
Rob H@RCH Engineering Posted May 15, 2013 Posted May 15, 2013 You can use the same key if you use the ep82 ecu as they dont have a coded key like the uk cars, the wiring is not that hard to do its only a case of swapping some wires in the ecu plugs and swapping some plugs over I have the wiring diagrams for doing it we did when I did mine years ago, but you will still need a ep82 loom and ecu for the engine. Quote
grimpigeon Posted July 16, 2013 Author Posted July 16, 2013 You can use the same key if you use the ep82 ecu as they dont have a coded key like the uk cars, the wiring is not that hard to do its only a case of swapping some wires in the ecu plugs and swapping some plugs over I have the wiring diagrams for doing it we did when I did mine years ago, but you will still need a ep82 loom and ecu for the engine. Could I grab those diagrams please? Quote
mikey4410 Posted July 16, 2013 Posted July 16, 2013 the 4efte ep91 goes straight into the uk spec ep91 n/a with no issues. did notice the uk had a transponder and immobiliser this all came out and didnt pose a problem when i replaced interior and engine loom the plugs on ignition are the same Quote
