i have a gready blue ecu mapped at 1 bar on a td04 and when I hit 200km off clock it cuts out and takes 3 seconds to go back to full power would this be a fuel cut on the map or top end still restricted if so what would I need ?
is that one of them hks sld ? because my clocks have 110 on the out side and 180 on the inside but it goes all the way past that looks to be around 125 200km
That's probably where your boost cuts out.. It will just die at the limit and then spoil back up again and just do the same ...
What are you expecting to get out of it? Lol
Ever thought your just hitting your top speed..
Edited by Matt1878
Its your speed limiter, you need a speedo convertor, screws onto you gearbox then the cable goes into that
Your dials have had a mph facial put on instead of the original kph ones so will need a set of kph ones with the K changed to an M ;)
Also the reason u go past it is a mixture of speedo error and the limiter being a bit slow to kick in.
Edited by morgey
