Arnold Posted May 28, 2013 Share Posted May 28, 2013 Hey guysCar has been set for a week and when parked, it was running alright. Drove it about half a mile but my gear lever went soft / no resistance. I tried to downshift into second and there was nothing there, the engine just revved as if I was in neutral. I managed to get first and parked her, but I cannot get any other gear apart from first. The clutch feels fine, and I couldn't see any hydrolic leaks. Also if I put it in reverse for example, the gear stick stays in the reverse position but I'm still in neutral. Not getting any strange noises from the gearbox though.Is it something up with my box and any ideas from my description what is needed to fix it? or could it be something else.Thank you Quote Link to post Share on other sites
mikey4410 Posted May 28, 2013 Share Posted May 28, 2013 your gear linkage cables seated in there brackets ok ? gea linkages not broken ? Quote Link to post Share on other sites
Arnold Posted May 28, 2013 Author Share Posted May 28, 2013 I couldn't see anything broken but it's hard to tell, the car is so low. Didn't see anything hanging down when I looked in the engine bay. If it was broken, I can't see how id be able to engage first gear? Quote Link to post Share on other sites
TurboTobz Posted May 28, 2013 Share Posted May 28, 2013 Have a check under your centre console it's a long shot but something may be in the way of the cables or they may have popped out Quote Link to post Share on other sites
mikey4410 Posted May 28, 2013 Share Posted May 28, 2013 worn linkages also,yea check for popping out etc and as for "will i be able to select first gear ",depends on which cable has failed (if any) Quote Link to post Share on other sites
Arnold Posted May 28, 2013 Author Share Posted May 28, 2013 Ahh ok, cheers will check that out. At least you've not said new gearbox etc so that's encouraging Quote Link to post Share on other sites
mikey4410 Posted May 28, 2013 Share Posted May 28, 2013 u need a new gearbox mate badly :-) Quote Link to post Share on other sites
Arnold Posted May 28, 2013 Author Share Posted May 28, 2013 I was going to stick a Quaife ATB in when it does eventually give in but I can't afford that right now! Just need it repaired for Japfest 2 Quote Link to post Share on other sites
mikey4410 Posted May 28, 2013 Share Posted May 28, 2013 so whats happeniing then dude ? found out the issue ? Quote Link to post Share on other sites
Arnold Posted May 28, 2013 Author Share Posted May 28, 2013 Lol no. I work full time and my car is in the garage, so I won't get a chance to look at this until tonight probably Quote Link to post Share on other sites
mikey4410 Posted May 28, 2013 Share Posted May 28, 2013 well dolet us know mate ! Quote Link to post Share on other sites
Arnold Posted May 28, 2013 Author Share Posted May 28, 2013 Of course Quote Link to post Share on other sites
Arnold Posted May 29, 2013 Author Share Posted May 29, 2013 Right guys, We've had a look and it does appear to be connected at the gearbox end, and you can see the linkage/mechanism move when the gears are engaged. One thing I've noticed is that the cable doesn't seem to sit in the hole. When I pushed it in, it seemed to engage one of the gears. When going back to neutral, it popped back out. I've uploaded a video to here : http://www.alanarnold.co.uk/glanza2/IMG_0698_Gearlink.MOV'>http://www.alanarnold.co.uk/glanza2/IMG_0698_Gearlink.MOV - and picture below. How do I fix this!?Thanks guys Quote Link to post Share on other sites
Broony Posted May 29, 2013 Share Posted May 29, 2013 newcables needed looks slack Quote Link to post Share on other sites
morgey Posted May 29, 2013 Share Posted May 29, 2013 (edited) Looking at that picture it looks like its snapped, or very nearly snapped, there should be a thickish cable going through that hole into the gaitor. Also I've never seen a tube coming of the speedo drive like yours before :s Edited May 29, 2013 by morgey Quote Link to post Share on other sites
The_Notorious_C_A_T Posted May 29, 2013 Share Posted May 29, 2013 (edited) As the guys have stated replace the cable. Looks to have snapped for the majority externally, although the inner cable might be hanging on in there just by the fact the outer casing has rotated and you can kind of get a gear.Found a few pics in my photobucket to give you an idea of what they look like removed from the car, might help give you a heads up of what you'll be up against replacing them: Edited May 29, 2013 by The_Notorious_C_A_T Quote Link to post Share on other sites
morgey Posted May 29, 2013 Share Posted May 29, 2013 (edited) Have you got rear footwell heater vents/air ducts? Them plastic tubes above the cables. Edited May 29, 2013 by morgey Quote Link to post Share on other sites
The_Notorious_C_A_T Posted May 29, 2013 Share Posted May 29, 2013 Yeah it did have. Quote Link to post Share on other sites
morgey Posted May 29, 2013 Share Posted May 29, 2013 I've never seen them before on a starlet! Quote Link to post Share on other sites
The_Notorious_C_A_T Posted May 29, 2013 Share Posted May 29, 2013 Didn't know it was a rare thing! Lol Quote Link to post Share on other sites
Arnold Posted May 30, 2013 Author Share Posted May 30, 2013 As the guys have stated replace the cable. Looks to have snapped for the majority externally, although the inner cable might be hanging on in there just by the fact the outer casing has rotated and you can kind of get a gear. Found a few pics in my photobucket to give you an idea of what they look like removed from the car, might help give you a heads up of what you'll be up against replacing them: This is great, cheers. Do you know how much the replacement cables cost and how long did it take you to fit? Or is it worth me just paying someone to do the job properly! Quote Link to post Share on other sites
The_Notorious_C_A_T Posted May 30, 2013 Share Posted May 30, 2013 I was fitting something else while I was dicking about with the cables so unsure of how long exactly it took. I would estimate an hour or 2 roughly to fit. I managed it so not a hard job but a bit fiddly at times. Quote Link to post Share on other sites
Arnold Posted May 30, 2013 Author Share Posted May 30, 2013 Does the plastic shifter part need to come out, carpet n all? or can it all be done in place. Quote Link to post Share on other sites
The_Notorious_C_A_T Posted May 30, 2013 Share Posted May 30, 2013 Carpet can stay in, all the surround needs to be taken off. Whether or not the plastic shifter housing has to come off, depends which cable but from the picture I would guess so although it was a long time since I did it! Quote Link to post Share on other sites
Arnold Posted May 30, 2013 Author Share Posted May 30, 2013 (edited) Ok mate. For anyone in the same bloody annoying position as me, here's some useful details from Toyota.Part 33821C x3 Rubber Bushings, £3.71Part 33821 x1 Left Gear selector cable £178.78Part 33822 x1 Right Gear selector cable £153.19Part 90468-14016 x4 Horse shoe clips £3.00 approxPart 90468-14034 x1 Clip £1.37Part 90468-14021 x1 Clip £1.25I've bought a second hand set of cables and shifter and will use those, but will be renewing all the clips, bushes, washers etc with the above. Should have it all by the weekendIll upload a diagram tomorrow so you can see what parts go where Edited May 30, 2013 by Arnold Quote Link to post Share on other sites
