redliner Posted May 30, 2013 Posted May 30, 2013 i bought 10mm wheel spacers put them on the hub then the wheels, but there not much thread there to catch the wheel nuts and dont think it was safe to drive,, any 1 got any ideas on what ta do to make them fit?? or just bin them? thanks ger,, Quote
Wills21 Posted May 30, 2013 Posted May 30, 2013 (edited) I only done this the other day, needed longer wheel studs 10mm makes a good difference on the back Edited May 30, 2013 by Wills21 Quote
redliner Posted May 30, 2013 Author Posted May 30, 2013 ah that is sweet lookin alrit , is there much hassle in doing it? an where can i get longer wheel studs?? cheers ger. Quote
morgey Posted May 30, 2013 Posted May 30, 2013 Ebay or motor store, fronts aren't too bad theres a cut out on the hub to knock them out and back in through, not sure on the backs im afraid. Quote
redliner Posted May 30, 2013 Author Posted May 30, 2013 Ebay or motor store, fronts aren't too bad theres a cut out on the hub to knock them out and back in through, not sure on the backs im afraid. ok cheers an what size are the studs and what length do i need do you know?? have you takin out the front studs urself?? Quote
Wills21 Posted May 30, 2013 Posted May 30, 2013 http://www.grp4fabrications.com/product_info.php?cPath=46&products_id=590 I got them in Icetronix because I needed them fast, they're 25mm longer than standard (whatever that is) Back studs I had to take the discs off to get the new studs in because they are too long Quote
morgey Posted May 30, 2013 Posted May 30, 2013 Yeah I've removed some before. Cant remember why though, think i had some corolla gti ones which were about 12mm longer so fitted them so i didnt need the collared nutsM12 x 1.5 is the thread Quote
redliner Posted May 31, 2013 Author Posted May 31, 2013 Yeah I've removed some before. Cant remember why though, think i had some corolla gti ones which were about 12mm longer so fitted them so i didnt need the collared nutsM12 x 1.5 is the threadok thanks bud, its not the hardest of a job ta do so? Quote
redliner Posted May 31, 2013 Author Posted May 31, 2013 http://www.grp4fabrications.com/product_info.php?cPath=46&products_id=590 I got them in Icetronix because I needed them fast, they're 25mm longer than standard (whatever that is) Back studs I had to take the discs off to get the new studs in because they are too long thanks for the link bud at least i can use them now,, did you use 10mm spacers on front aswell?? Quote
Wills21 Posted May 31, 2013 Posted May 31, 2013 thanks for the link bud at least i can use them now,, did you use 10mm spacers on front aswell?? No just the rears mate, didn't need them on the front. Where did you get your spacers? Quote
morgey Posted May 31, 2013 Posted May 31, 2013 No fairly easy get the disc and caliper out the way. And its a case of rotating it to the place on the hub with clearance and smacking out each one and then reverse the process putting them back it Quote
redliner Posted May 31, 2013 Author Posted May 31, 2013 No just the rears mate, didn't need them on the front. Where did you get your spacers? oh i need them on the front, ah got them from barry`s motorsport cork, 40euro for the 4 of them, so the studs you gave me the link to they will do the trick yea? Quote
redliner Posted May 31, 2013 Author Posted May 31, 2013 No fairly easy get the disc and caliper out the way. And its a case of rotating it to the place on the hub with clearance and smacking out each one and then reverse the process putting them back it ok thanks, sounds straight forward enough then,, Quote
Wills21 Posted May 31, 2013 Posted May 31, 2013 oh i need them on the front, ah got them from barry`s motorsport cork, 40euro for the 4 of them, so the studs you gave me the link to they will do the trick yea? I'm 90% sure, not 100% sure the spline count on the inside is the same though as I got different one's. Ring them to make sure maybe That was a good price for the spacers, I paid €30 for two lol Quote
redliner Posted May 31, 2013 Author Posted May 31, 2013 ya il ring them an make sure, when u were buying the spacers did they say anything about needing longer wheel studs?? i was told noting about them not fitting,, bad form really i think when you have to find out for yourself,, Quote
