Well after a quick diagnostics, got theses codes.
24 = air temperature sensor
25 = running lean
41 = TPS
What would cause these all to go at once?
Its definitely not running lean, black smoke.
Edited by chrisgreen1993
Cleaning the idle control valve also removed error code 41?
I think if the ICV go's down then the other sensors wont be reading correctly!!!
Thanks, have to try it as I have error code 41 and haven't figured out it yet
If you take the ICV off, and just plug it in there is no error codes, it only pulls up the error codes when on the TB.
Another note, if you turn the nipple that the ICV goes on to you can adjust the idle.
