right the timing is bang on but the engine still dips in revs, kinda revin up and down up and down.
now, im wonderin, because I've still not put the glanza fuel pump in yet, would the SR pump be the cause of this issue as it doesnt pump as much fuel as the standard glanza 1?
and before anyone suggests, all vac lines are were they should be and the map sensor plugged in etc etc
cheers boys
nope
idle control valve try that? take it off and clean.. again mine used to rev up and down (hunt) when I had my GT and I cleaned this and it stopped.
just a idea
After watching your startup vid in another thread i'm pretty convinced its a vac issue somewhere. Even a tiny split in one would cause this.
But defo take off the ICV off the inlet and give it a blast with brake cleaner.
Is the inlet to throttle body gasket in good condition man, and the bolts right tight ?
