im after the following for an ep82;
radiator bottom hose
thermostat flange housing (the part the stat sits in, has a 2 bolt flange)
throttle position sensor
de-cat or standard cat
lambda sensor
knock sensor (presume it has a small length of wiring to it?)
power steering pump bracket, my pump doesn't line up with the adjuster?
let me know what you have, cheaper the better ideally.
