Lawless Posted June 4, 2013 Posted June 4, 2013 (edited) Just bought a mines plug and play ecu fr whitenoise was really helpful and gave me some info but basically I just want to no can this be run on my stock setup I have a stainless exhaust uprated leads and that's it (will it be safe to use)Engine is healthy low mileage ect services regularly And the question I didn't want to ask were is the standard ecu located am I right in thinking its under the glove box also when fitting it do I need to leave it to idle for any amount of time or drive carefully for a number if miles Any help opinions appreciated Thanks Edited June 4, 2013 by Lawless Quote
Addymk2 Posted June 4, 2013 Posted June 4, 2013 Yeah it's behind the glove box. Should be fine on your setup. Disconnect battery, unplug old ECU, plug in new ECU, leave to idle for about half an hour then kick her tits in. Pretty sure theres a guide on here for it bud. Quote
TrisK Posted June 4, 2013 Posted June 4, 2013 Glanza its behind glove box. Gt its like under the radio, you can get to it from drivers foot well Quote
Lawless Posted June 4, 2013 Author Posted June 4, 2013 Ok yea forgot to say its a gt not a glanza and its also stock running stock turbo and boost Thanks Quote
Amjad Posted June 4, 2013 Posted June 4, 2013 On 6/4/2013 at 8:46 AM, Addymk2 said: Yeah it's behind the glove box. Should be fine on your setup. Disconnect battery, unplug old ECU, plug in new ECU, leave to idle for about half an hour then kick her tits in. Pretty sure theres a guide on here for it bud. You don't wanna kick it's tits in lol I've written what to do loads of times, have a search... Quote
Lawless Posted June 4, 2013 Author Posted June 4, 2013 On 6/4/2013 at 8:58 AM, Amjad said: You don't wanna kick it's tits in lol I've written what to do loads of times, have a search...Got a link dude I can't seem to find anything ? Quote
jimmymac101 Posted June 4, 2013 Posted June 4, 2013 Once you find your ecu, stick in the new one Unplug your battery for 20mins to reset the ecu Reconnect battery Let the car idle for 15minsTake it for a slow drive through the gears Once you done the slow drive give it some beans through the gears Then let it cool down and your done That's what we do with starletsr? Glanza as he has a JAM ecu James Quote
Amjad Posted June 4, 2013 Posted June 4, 2013 ^James has got it there. When you're driving, slowly add a little boost Go through the gears with 0.1bar, 0.2bar, etc until you reach full boost. But I wouldn't boost until you've been driving around off boost for 10-15mins Quote
Addymk2 Posted June 4, 2013 Posted June 4, 2013 My Zep and Blitz ECUs both recorded decent AFRs using both methods I personally find it more fun giving her a kicking lol Quote
Amjad Posted June 4, 2013 Posted June 4, 2013 Better safe than sorry, I've know of some people who went flat out quickly and the car misfired etc Quote
Lawless Posted June 4, 2013 Author Posted June 4, 2013 On 6/4/2013 at 12:24 PM, Amjad said: Better safe than sorry, I've know of some people who went flat out quickly and the car misfired etcMy thoughts exactly had a bad run with this car finally got it to a stage I can begin to modify and will not be hammering it till I'm sure it's ready ha ha Thanks Quote
jimmymac101 Posted June 4, 2013 Posted June 4, 2013 Do as I said above mate and your be fine and once you finished and cooled down, the next time you drive her you notice a major difference James Quote
Foggy Posted June 4, 2013 Posted June 4, 2013 I fitted a good few of them. No need to disconnect the battery or anything like that. Just have the ignition off.Remove old plug in new. Simple as that. Drive away. No need to drive slowly. Ecu might take up to a week or more to come right. Quote
