Dickydan Posted June 13, 2013 Posted June 13, 2013 Is the seals all fine buddy? If so it wint need a rebuild if its only slight play Quote
jimjam Posted June 13, 2013 Author Posted June 13, 2013 I'm not sure buddy :/ as don't know a lot about turbos Quote
Glanza-Ben Posted June 14, 2013 Posted June 14, 2013 If this is the ct12 that's on eBay Aswell it won't fit straight on a starlet and it has different manifold set up by looks of it Quote
jimjam Posted June 15, 2013 Author Posted June 15, 2013 It is the one from eBay but you could still get it to fit if you got another manifold Quote
Glanza-Ben Posted June 15, 2013 Posted June 15, 2013 Yea if you got a different manifold it would fit like any turbo will but you stated above that it will fit the ct9 manifold Quote
jimjam Posted June 15, 2013 Author Posted June 15, 2013 I said I don't know if it fits if you read the above posts buddy Quote
Glanza-Ben Posted June 15, 2013 Posted June 15, 2013 Dan I looked into it and apparently they do fit straight on to a ct9 manifold and I don't think there is any play in the shaft Quote
jimjam Posted June 15, 2013 Author Posted June 15, 2013 (edited) I said apperently so i didnt say they defiantly fit did i? And then if you look further down the comments you will see after seeing what everyone had then said I don't know? But ill change it ok. I only looked on the web and they said it fit so I'm very sorry for reading something that was wrong Edited June 15, 2013 by jimjam Quote
jimjam Posted June 17, 2013 Author Posted June 17, 2013 Well hasn't been used for a while so could do with a check up Quote
