Turbo Goose Posted June 7, 2013 Posted June 7, 2013 On the starlet rear arch there is the smallest and I mean smallest bubble just appearing on the edge of the arch (on the inside)how can I stop it getting any bigger? Is paint enough or does it need treatment?I just don't want any salt to get under it and spread. Its literally not noticable without really looking but don't want it to become noticable Quote
StuDoc 72 Posted June 7, 2013 Posted June 7, 2013 You will find underneath the tiny bubble on the paint that the rust will be slightly worse underneath. Its all a case of just how bad. The best way to solve this would be to use an angle grinder and slightly take it back to bare metal untill you have removed every spec of rust. Then key prime paint n laquer. If it is worse you may have to apply a little bit of treatment to it but these arent expensive and are widely available. Quote
Rob H@RCH Engineering Posted June 7, 2013 Posted June 7, 2013 The most effective way of stopping it coming back is to use a spot sandblaster. It will remove very little of the metal but gets deep into it to remove the corrosion. Or you can use rust converter stuff that like an acid that kills the corrosion and stops it then paint over the area. Grinding takes too much of the steel away for me on panels that are very thin to start with. One thing to be sure of is you get the treatment well into the joint of the two panels as thats were it will have started. This is what I would use http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_179549_langId_-1_categoryId_165594 Quote
pacman Posted June 7, 2013 Posted June 7, 2013 Can't really add much to what's been said above but personally I'd use this product: http://www.amazon.co.uk/Jenolite-JRR045-150g-Rust-Treatment/dp/B002SLHLYM Quote
Patches Posted June 7, 2013 Posted June 7, 2013 I've recently bought this stuff called por-15. Its supposed to be the best stuff out, i think the yanks make it. Very expensive mind you but im going to use it to underseal my car Quote
Ct9 Posted July 4, 2013 Posted July 4, 2013 Be careful with underselling boys as you may seal some moisture in and it will rot from the inside out. If it were mine I would wax oil it as it acts as a barrier but will still allow damp out . Quote
