dangarbutt Posted June 11, 2013 Posted June 11, 2013 puting my gt box with quaife diff in in next few weeks anyways the guy i got it off give me a liter of unmarked unbranded oil and said thats what a company told him to use anyway am i hell using that! ,,,,, so can anyone tell me what oil i should be using certain people say normal other say it must be quaifes own any ideas anyone ??? Quote
lugzy clart Posted June 12, 2013 Posted June 12, 2013 I got a quaife diff in my box n u can run normal box oil. There a maintenance free diff tbh should be no noises or n e thing ull love it once installed Quote
Arnold Posted June 12, 2013 Posted June 12, 2013 ^ What he said, although I haven't got one yet and I want one BAD Quote
Jamie1st Posted June 12, 2013 Posted June 12, 2013 Either Toyota 's own oil, or a 75:90 fully synth Quote
Rob H@RCH Engineering Posted June 12, 2013 Posted June 12, 2013 Quaif state on there site you can use any oil you like basically, I run mine on ATF because it makes for a nice smoooooth gear change! Quote
dangarbutt Posted June 12, 2013 Author Posted June 12, 2013 lots of info good good lugzy you may have to educate me on how they should feel ect but thanks for the info Quote
rasslenny Posted June 13, 2013 Posted June 13, 2013 may be a stupid question but ill ask any way if i buy the quaife lsd is it as simple as opening the exsisting box and replacing the open diff in the housing with with quaife... and that is it slap box back on, attach axles and have fun boosting again ? Quote
AdamB Posted June 13, 2013 Posted June 13, 2013 may be a stupid question but ill ask any way if i buy the quaife lsd is it as simple as opening the exsisting box and replacing the open diff in the housing with with quaife... and that is it slap box back on, attach axles and have fun boosting again ? Yep pretty much, obviously you have to unbolt the final drive from the old diff and bolt it back upto the new one. Some diff's do require a running in period where your supposed to do figure of 8's for 30 minutes, although I don't think this applies to the quaife as it is not a clutch type LSD. Quote
rasslenny Posted June 13, 2013 Posted June 13, 2013 (edited) hmmmmmm does that warrent 600 pounds though ughhh sooo expensive Edited June 13, 2013 by rasslenny Quote
lugzy clart Posted June 13, 2013 Posted June 13, 2013 lots of info good good lugzy you may have to educate me on how they should feel ect but thanks for the info Should feel like a normal g box until u put it on boost then just don't expect to be hanging about wheel spinning all over the place lol. First time I drove mine wen I got it back it was wet out n f**k me it just went n I took the mountains home n worked amazing in all the corners n held so much more speed coming in them Also taggy has a how to I think on wiki on how to fit 1ill see if I can find it later Quote
lugzy clart Posted June 13, 2013 Posted June 13, 2013 http://www.ukstarletowners.com/topic/59358-a-guide-to-fit-an-aftermarket-quaife-lsd/ This is the link to it n got all the info any 1 should need Quote
dangarbutt Posted June 14, 2013 Author Posted June 14, 2013 Should feel like a normal g box until u put it on boost then just don't expect to be hanging about wheel spinning all over the place lol. First time I drove mine wen I got it back it was wet out n f**k me it just went n I took the mountains home n worked amazing in all the corners n held so much more speed coming in them Also taggy has a how to I think on wiki on how to fit 1ill see if I can find it later just another quick question lets say im just crawling allong round a corner then give it the full beans will the diff not just lock and start bumping the front end across the road?,, Quote
AdamB Posted June 14, 2013 Posted June 14, 2013 No, diffs have an active preload setting where they will not lock until they see X amount of torque, this can be adjusted on clutch type LSD's, not sure on the quaife though. Quote
