chrisholly Posted June 12, 2013 Share Posted June 12, 2013 HI guys I really need help my car is throwing water out the coolant bottle now and again its not really getting hot till it starts to kick it outany idea's I have no knocks just a little blow from the manifold and had a oli change also I have to change it like each week because its making the oil really thin??? Quote Link to post Share on other sites
jtaylor1990 Posted June 12, 2013 Share Posted June 12, 2013 Headgasket maybe? Quote Link to post Share on other sites
DavidAshton Posted June 12, 2013 Share Posted June 12, 2013 Head gasket has failed. Quote Link to post Share on other sites
StuDoc 72 Posted June 12, 2013 Share Posted June 12, 2013 Soooooo true lol. Either that or cracked block. Quote Link to post Share on other sites
Chesh Posted June 12, 2013 Share Posted June 12, 2013 Yep sounds like headgasket has gone Quote Link to post Share on other sites
AdamB Posted June 12, 2013 Share Posted June 12, 2013 Headgasket, wouldn't drive it anymore as you'll be flooding the cylinders with water and will end up even more costly. Quote Link to post Share on other sites
StuDoc 72 Posted June 12, 2013 Share Posted June 12, 2013 (edited) Headgasket, wouldn't drive it anymore as you'll be flooding the cylinders with water and will end up even more costly. Think it might be going the other way mate. Regardless though could warp the head if it continues to overheat. Edited June 12, 2013 by StuDoc 72 Quote Link to post Share on other sites
chrisholly Posted June 13, 2013 Author Share Posted June 13, 2013 ohhh dear ;( how much will I be looking at? Quote Link to post Share on other sites
akyakapotter Posted June 13, 2013 Share Posted June 13, 2013 I payed best part of £700 when I had my hg done every thing uprated though Athena gasket uprated valve stem seals cam belt water pump aux belt power steering belt head pressure tested and skimmed arp head bolts Quote Link to post Share on other sites
chrisholly Posted June 13, 2013 Author Share Posted June 13, 2013 someone said to check things to see if its gone its all ok but it oil is old and needs a change it old oil make it play up like that its been ok for 3 day's since I changed the water and coolant Quote Link to post Share on other sites
