AndyMB Posted June 13, 2013 Share Posted June 13, 2013 My clutch has started to squeak when being depressed. Sounds like a seagull! You can feel it getting tight as you go further down. Tried spraying it with spray lube but no luck. Don't think it's the cable. Any ideas? Quote Link to post Share on other sites
rinseep82 Posted June 13, 2013 Share Posted June 13, 2013 It's deffo not the cable because they are hydraulic baybe the clutch release bearing mate Quote Link to post Share on other sites
daniel_g Posted June 13, 2013 Share Posted June 13, 2013 Theres a spring above your left foot that can squeek. Or is the squeek coming from inside the gearbox ?? Quote Link to post Share on other sites
akyakapotter Posted June 13, 2013 Share Posted June 13, 2013 ^^^^ spring on my squeaks dose my head in Quote Link to post Share on other sites
daniel_g Posted June 13, 2013 Share Posted June 13, 2013 A mouse lives in mine like. Quote Link to post Share on other sites
rinseep82 Posted June 13, 2013 Share Posted June 13, 2013 Is it Cumming from inside the car?? Quote Link to post Share on other sites
AndyMB Posted June 13, 2013 Author Share Posted June 13, 2013 Pretty sure it's inside the car, seen that spring, tried spraying it in oil. Pretty sure it's that, has that kind of rough squeak to it. Can you buy new ones anywhere? Or can it be quietened down? Doing my head in! Quote Link to post Share on other sites
5T4R7ET N/A Posted June 14, 2013 Share Posted June 14, 2013 mine does the same and i had it before in my other starlet. only happens when you push the cluch down the squeak comes from under the the rubber boot were clutch slave cylinder arm is making contact with the clutch fork. Quote Link to post Share on other sites
