Big_T-SR Posted September 17, 2007 Posted September 17, 2007 Hey guys,I need to change my speedo and rev count in my toyota starlet sr. I need one that can rev up to 8000rpm and for the speedo to go higher than my 120mph. Does anyone know if any other cluster would fit into the sr? I can just unplug the rev count and get a seperate rev meter, but i'd prefere it if the dials were changed. Would the AE111 cluster fit?Also open to suggestions, thanks.T Quote
Sparky Posted September 17, 2007 Posted September 17, 2007 A Paseo Binnacle will fit and the clock faces are white and go to 130mph if thats any good??? Think the wiring may need a slight modification for it to work though...hopefully someone else will clear this up Quote
Mikey Jay Posted September 17, 2007 Posted September 17, 2007 Not sure if the AE111 cluster will fit, buuut, as the Levin is now at my house, can get a tape measure and see if from a size perspective it'll fit.if that helps?(can compare it to my Paseo cluster, which is the same size as the Starlet cluster) Quote
RobSR Posted September 17, 2007 Posted September 17, 2007 cant you just get someone to make up some custom faces, the whole unit shouldn't have to be changed..... Quote
SiCaln Posted September 17, 2007 Posted September 17, 2007 you can but u need to get the speedo recalibrated Quote
Guest Enzo Posted September 17, 2007 Posted September 17, 2007 the ae111 cluster will fit, a boy over on the sister au site has a black top 4age transplanted along with the wireing and cluster Quote
shelly_star Posted September 18, 2007 Posted September 18, 2007 What a coicidence... i'm trying the same thing. Thats why i need it to rev up to 8 Do you have a link by any chance geo? Mucho appriciente.T... Just realised.. i hadnt signed out.... anyways.. this is Tony. Quote
Big_T-SR Posted September 24, 2007 Author Posted September 24, 2007 I've joined the Aussie forum, but i haven't found the specific post your talking about geo.But I've decided to go for a seperate tachometer as i'm not likely to go farther than 120mph as we all here are safe considerate drivers ;DT Quote
