TrisK Posted June 24, 2013 Posted June 24, 2013 Can i compression test an engine with it out the car? or am i not going to be able to turn it over fast enough? Maybe ill have to do a leak down test? Quote
StuDoc 72 Posted June 24, 2013 Posted June 24, 2013 Not really as you should really test it on a warm engine. Yes you also need quite a quick turn over. You could easily bolt the gearbox onto it and the starter if you have them should be a canter since its not in the car. Quote
AdamB Posted June 24, 2013 Posted June 24, 2013 (edited) Having the engine warm makes little to no effect on the reading you get anyway, although ideally it should be tested when warm. A leak down test would be far better as it is a lot more accurate than a compression test. Anything more than 5% leakage indicates a serious problem. Edited June 24, 2013 by AdamB Quote
daniel_g Posted June 24, 2013 Posted June 24, 2013 Id expect leakage on an old FTE to be a bit more than 5% tbh. Quote
AdamB Posted June 24, 2013 Posted June 24, 2013 Id expect leakage on an old FTE to be a bit more than 5% tbh. Depends what you want to use the car for tbh. A car to run to the shops and back will be fine with upto 20% leakage, but looking for a good performance motor 5% would be ideal. Quote
StuDoc 72 Posted June 24, 2013 Posted June 24, 2013 Id have to agree with Daniel. Also ofcourse temp matters. Metal expands when warm - engines are metal. Its simple physics. Quote
TrisK Posted June 24, 2013 Author Posted June 24, 2013 Basically, i have a engine with knackred big end bearings. im going to replace them with out stripping the whole thing (just sump off), but i want to confirm everything else is spot on before i put it in a car, and get a shock that a ring was gone too or something else etc Quote
daniel_g Posted June 24, 2013 Posted June 24, 2013 Well i can pretty much guarantee that a 15 year old + FTE will have a greater leakage than 5%. Trisk, you could replace the bearings and do a leak test before you put it in the car or whatever. Providing you have / can get a loan of an air line obv. Quote
