Nope.
They have enough power its more to do with when the gearbox is out of steam.
As far as im aware they are good for 160.
Someone more clued up on the ratios can be more specific though.
Edited by StuDoc 72
Not sure at standard as I've never tried.
Put it this way in 5th gear you hit the limiter of 112mph at 5k rpm.
Now the car will rev to 7800rpm so you do the math.
What difference does it make anyway? Not that its much use to anyone.
Unless your in a playground dick measuring contest.....
Standard they will do 135 iirc with the limiter removed.
I've been 157mph in mine but I do belive the gearbox maxes at 159mph
I've seen 127mph on satnav speedo was past the end of my clock. Prob around the 135-140 on the speedo area. Car was still going but ran out of track.
Thats with 175hp but reckon it would struggle to get much more than 135 satnav speed, which would put it at 145-150 speedo
Oh and bear in mind mines n/a so dont have the torque of the turbo boys ;)
Edited by morgey
Believe the boxes are geared to like 168'ish, although this varies on drag coefficient, tyre size, wheel size, torque. Will easily hit those sorta speeds on a dyno but in the real world would probably be quite unlikely without a lot of power.
^^^ yeah thats the biggest factors.
I think i read somewhere it takes about 270hp (not sure on what torque) to hit 170mph but thats the limit of our boxes with the stock 7800 limiter and you have to hope both power and torque are still climbing at that point.
Edit: thats in general for any car not specific to starlets by the way
Edited by morgey
If ya want to get all technical theres a equation you can do.
Roughly 0.000008702 x drag coeffient x frontal area x desired speed (cubed)
Seems an ep91s drag is 0.33 frontal area is hard to judge but they do it for a 288 gto ferrari at 20.5 so you can assume ours is bigger and disired speed of say 170mph
So with a frontal area of say 25sqr ft?? Might be a bit big? Lol
0.000008702 x .33 x 25 x 170 (cubed) = 352
You would need 352whp do to 170mph
But for every .5 extra square footage frontal area you need 12whp to do the same speed or the opposite if it were smaller
Change the desired speed to 130 mph and you need 157whp
This is also out as they did theres for a rwd car and ours are fwd the front area is just a guess as well but you get the idea
Info from here
http://www.bobnorwood.com/300%20mph%C2%A0%20The%20Aerodynamics%20of%20Drag%20and%20Power.htm
Edited by morgey
Starlets aren't so good at top speed because they are a short wheel base and become unstable when compared to a car with a larger wheel base. But this does make them good on the twisties, and thats where big balls matter :thumbsup:
