May seem like a stupid question but new to turbos. The car came with a Blitz BOV do you just take it off and connect the pipes as it it wasn't there? Don't you get chatter from compressor surge? I was always under the impression that was bad for the turbo, much appreciated if someone can enlighten a novice willing to learn
Remove it or the vacuum pipe or adjust it so the springs tougher. plenty of people run like this problem free, I for one don't have a bov connected!
You can get it by slowly releasing your throttle too.
Just remove the blow of valve, and block up any pipes or holes that are left over.
Failing that, you can shout "choo choo choo" out of the window when you change gear.
As above,the choo choo method is extremely valid and is a common chatter noise.
An unrestrictive short as possible air filter and piping ,and no dump valve.
