knock code mean experienced knock or just fault ?
It means the engine is knocking.
You can test the sensor with a multimeter.
The knock sensor can also go off if you hit a big pothole or bump at high speeds.
  • 3 weeks later...
how do you remove the plug from the sensor without taking the inlet mani off, i can reach it with my hand but can seem to get it off
Underneath is the best way, there is a bracket that's connected by 3 nuts, 1 just underneath the "Knock Sensor" if i'm not mistaking it's 12mm or 14mm and the other 2 are connected underneath the "Intake Manifold" after that u can reach it easily.
And with a 27mm Deep Socket just screw it off and your done hope this helps.
