glanza sheehy Posted July 21, 2013 Share Posted July 21, 2013 sick of it at this stage, thought it was fixed as i changed the alternator and battery yesterday as i thought that was it but on the way to cork today but the car was acting up again and ended up in leaving the car in a car park..i also changed the king lead today, but there was no difference.when i left cork the revs were bouncing away again for 5 minutes or that way, cruising on the way home there was no problems until i came to back roads when i had to go to low gears or stop where the revs would bounce away again and engine management light came on. it was getting slightly dark when i was nearly home so i put on my lights and the revs would bounce immediatley, this surely has something big to do with it? any info much appreciated Quote Link to post Share on other sites
glanza sheehy Posted July 22, 2013 Author Share Posted July 22, 2013 battery was dead while ago after i getting a new one and changing the alternator? Quote Link to post Share on other sites
PaulStarletSR Posted July 22, 2013 Share Posted July 22, 2013 vac leak Quote Link to post Share on other sites
glanza sheehy Posted July 22, 2013 Author Share Posted July 22, 2013 vac leak do i just get new vac pipes so? that wouldnt have anything to do with draining the battery though? Quote Link to post Share on other sites
mikey4410 Posted July 22, 2013 Share Posted July 22, 2013 What do u mean by revs bouncing,trying to understand so i fan try and helpIts goin up and down of its own accord between what revs and when,at idle or driving along.? Quote Link to post Share on other sites
glanza sheehy Posted July 22, 2013 Author Share Posted July 22, 2013 What do u mean by revs bouncing,trying to understand so i fan try and helpIts goin up and down of its own accord between what revs and when,at idle or driving along.?anything between 4.5 to conking. and both at idle and driving along. i cant put on lights as it gets worse. Quote Link to post Share on other sites
mikey4410 Posted July 22, 2013 Share Posted July 22, 2013 Hmm im not gonna lie,i havent a clue with this im sorry Quote Link to post Share on other sites
TurboTobz Posted July 22, 2013 Share Posted July 22, 2013 Usually hunting is a sign of vac leak, I had this randomly and car would jolt if i had my foot off the throttle and was in gear coasting, I'd replace or check all vac hosing and clean icv and possibly reset tps? Quote Link to post Share on other sites
glanza sheehy Posted July 22, 2013 Author Share Posted July 22, 2013 thanks for the info lads Quote Link to post Share on other sites
TurboTobz Posted July 23, 2013 Share Posted July 23, 2013 Maybe unplug tps aswell, and icv one by one see if it disappears Quote Link to post Share on other sites
glanza sheehy Posted July 25, 2013 Author Share Posted July 25, 2013 changed a fuse and everything is fine now? :/ Quote Link to post Share on other sites
mikey4410 Posted July 25, 2013 Share Posted July 25, 2013 The fuse may have been to the map sensor or similar. Quote Link to post Share on other sites
glanza sheehy Posted July 26, 2013 Author Share Posted July 26, 2013 revs still bouncing people. it seems if i leave the car alone for a day or two it will be ok and a day or two later it starts acting up again? Quote Link to post Share on other sites
RobSR Posted July 27, 2013 Share Posted July 27, 2013 Get a video of it? Does sound like a hunting idle due to an airleak tho. even a little split in a vac line can cause it; Quote Link to post Share on other sites
Danza V Posted July 30, 2013 Share Posted July 30, 2013 I had this a while back in my v and ended up scratching my head because I never cured it. I replaced the pcv, cleaned the bov, bled the coolant system, checked all vac lines, checked iacv, Didn't check the tps though. Could check the cable or throttle body? I always thought that on mine I was getting boost spikes though :/ Quote Link to post Share on other sites
glanza sheehy Posted August 1, 2013 Author Share Posted August 1, 2013 now its happening when idle to? and the car now and again does a massive backfire and engine managment light would also come on Quote Link to post Share on other sites
