iamlegend Posted July 25, 2013 Posted July 25, 2013 (edited) getting this SLIGHT vibration in the steering wheel when doing speed up to 80-90mph it vibrates alittle... now this has only happend since fitting new ebc discs/yellow pads and hand brake cable/braided brake lines ... could be a coincidence?? I have had the following checked by revolution motorstore 3 times now for the following rota wheels are fine not had a knock etcwheel balance x4spigot rings x4cv joints suspension is new well bc coilovers said looked at the steering rack and all seemed great.. does your wheel vibrate ever so slightly at these speeds? as I kno there small cars and I did read a thread ages ago what "starletrick" said this happend to him the steering wheel vibrates over a ton! any other ideas??? when I say slight vibration in steering wheel it is not mental or anything but can notice it... other thing mabys the new discs are warped? but surley this would only wiggle on sudden brake which it does not.. Edited July 25, 2013 by iamlegend Quote
A L 3 X Posted July 25, 2013 Posted July 25, 2013 Mine does this ever so slightly but I am very picky lol Quote
daniel_g Posted July 25, 2013 Posted July 25, 2013 Normally would be wheel balance, but if its been checked 4 times lol. What about the balancer on the driveshaft ? Is it worn at all ? Quote
Critic Posted July 25, 2013 Posted July 25, 2013 Is it not just the new pads rubbing a bit? If it is, it should go away once the pads wear down a bit. Quote
Danb Posted July 25, 2013 Posted July 25, 2013 Don't go over 90......LolHow many miles you done with the new brakes? Quote
