Which bushes on the car are the most important to upgrade?
I have no handerling mods on my v and would like to invest in some which ones would I most benefit from
Thanks matt
Its prob best to do all bushes as these are quite old cars now.it would be of benifit definatley. As said above powerflex are very good.also u can do ure engine bushes as this is meant to help handling also.
The polybushes usually come in seperate kits and its not a bad idea doing them in stages as they arent easy to get out( the old ones) .i did mine over the space of three months or so.spreads the cost out then.
Not a bush but having new ball joints is a good place to start, takes the floaty feeling out the steering.
Fire, hammer & chisel will get most of them out. Or a press if you have one to hand. Also the use of a bench vice.
For the bushes i mean ^^
