Collins611 Posted August 4, 2013 Posted August 4, 2013 How do u know if your fcd is working I currently put new setup on my starlet Td04Fuel pressure reg And fuel cut Set at 1.0How do ou know if it supports the fcd Quote
PaulStarletSR Posted August 4, 2013 Posted August 4, 2013 U wont hit fuel cut lol fuckin lol charlie. statin the obvious since 2013 Quote
TurboTobz Posted August 4, 2013 Posted August 4, 2013 Did you have the fpr and FCD set up with some sort of afr monitoring? Be it dyno/wideband? Quote
Collins611 Posted August 5, 2013 Author Posted August 5, 2013 Cheers lads I know and makin me sound like a twat I was only asking for info on it I have td04 when would normal fuel cut kick in ? Just I don't wanna be boosting 1.0 and it not fuel ?And am going on a wide band today Quote
Weyro Posted August 5, 2013 Posted August 5, 2013 boost cut usually happens at around 0.85barwhat kind of fcd do you have?and what is your fuel pressure set at? Quote
mikey4410 Posted August 5, 2013 Posted August 5, 2013 U will need at least a wideband a/f to see whats happening past .85 to be safe. Quote
Collins611 Posted August 5, 2013 Author Posted August 5, 2013 Hks and set on 8 Fuel pressure set at 45psi Ye I'm havin a friend put a wideband in exhaust and seeing if its rich and lean ? Quote
bucketep91 Posted August 5, 2013 Posted August 5, 2013 Lighten up mate, ask a silly question and ul get a silly answer. What else did u expect? Quote
Weyro Posted August 5, 2013 Posted August 5, 2013 those setting sound fine, maybe put the fuel pressure up a bit, just to be on the safe side till its got a wideband Quote
gazza g Posted August 19, 2013 Posted August 19, 2013 is it a gt or a glanza? if its a GT you can look at the stock pressure gauge and as you turn the POT on the FCD you will see it change position as this is just ofsetting the signal to the ECU, this is how i checked mine lol other than that you can measure the output at the FCD with a meter with the ign on and see the voltage output change. Quote
