Chrishoughton1989 Posted August 16, 2013 Posted August 16, 2013 Please help. Just started idling around 1.5 - 2 k ? Sometime erratic. Any ideas ? Thanks. Quote
TurboTobz Posted August 16, 2013 Posted August 16, 2013 adjust throttle pulley/tps/clean or replace icv/vacuum leak The search function should bring up the usual suspectsidle screw in inlet aswell Quote
PaulStarletSR Posted August 16, 2013 Posted August 16, 2013 Leak of the vacuum variety.fuckin sick of vac leaks adjust throttle pulley/tps/clean or replace icv/vacuum leak The search function should bring up the usual suspectsidle screw in inlet aswellDO NOT touch the idle screw, wont be that if its just started doin it. just check tps and clean icv.also check if your dizzy is loose Quote
TurboTobz Posted August 17, 2013 Posted August 17, 2013 Could have vibrated itself back off nothing wrong with adjusting it with that screw if there's any adjustment left on it Quote
PaulStarletSR Posted August 17, 2013 Posted August 17, 2013 would check everythin else first before resortin to the screw tho. just to b safe Quote
PaulStarletSR Posted August 17, 2013 Posted August 17, 2013 What's unsafe about the idle screw? now your splittin hairs. check the more obvious things before goin for the screw because if he does the screw first, then the others without checkin with the engine on for example and the problems still there when he does turn her over, hws he gona know if hes got it? u get me? Quote
TurboTobz Posted August 17, 2013 Posted August 17, 2013 That's splitting hairs ^LolHow ever ya wanna try it you have a good list of starting points, if you adjust the idle screw do it with it running so you can hear if it's bringing the revs back down. Quote
PaulStarletSR Posted August 17, 2013 Posted August 17, 2013 I've got a feelin its his dizzy tbh Quote
PaulStarletSR Posted August 17, 2013 Posted August 17, 2013 2 10mm bolts hold it on, perhaps they r loose because it does seem to speed the rpm up or down when altered Quote
PaulStarletSR Posted August 17, 2013 Posted August 17, 2013 A good idle on a 4efte is feckin rare u heard mine?lol Quote
TurboTobz Posted August 17, 2013 Posted August 17, 2013 Not since you were having troubles, you got it sussed now right? Quote
PaulStarletSR Posted August 17, 2013 Posted August 17, 2013 Not since you were having troubles, you got it sussed now right? lol nope. but il tell u sumthin, standin behind it, hearin the Fujitsubo.........my fuckin god! any vid I've seen of 1s only been runnin a ct9.....this with a TD04 n 5efhe cams sounds utterly sexual and throaty! soo powerful soundin, its amazin! Dyin for its first drive mate, seriously chokin for it Quote
TurboTobz Posted August 17, 2013 Posted August 17, 2013 Oo sounds good gotta love a deep exhaust that sounds powerful!! Quote
PaulStarletSR Posted August 17, 2013 Posted August 17, 2013 its the valve thats bolted to the left hand side of the inlet manifold Quote
Chrishoughton1989 Posted August 17, 2013 Author Posted August 17, 2013 Would bad earth cause this ? Quote
TurboTobz Posted August 17, 2013 Posted August 17, 2013 ICV is on left of inlet maybe worth checking CTS too (theres two one is just signal to gauges other provides ecu with signals) Quote
Chrishoughton1989 Posted August 17, 2013 Author Posted August 17, 2013 Could a bad earth cause this ? Quote
Chrishoughton1989 Posted August 18, 2013 Author Posted August 18, 2013 (edited) Found problem thanks Edited August 18, 2013 by Chrishoughton1989 Quote
