  On 8/16/2013 at 9:17 PM, mikey4410 said:
Leak of the vacuum variety.
fuckin sick of vac leaks
  On 8/16/2013 at 10:40 PM, TurboTobz said:
adjust throttle pulley/tps/clean or replace icv/vacuum leak
The search function should bring up the usual suspects
idle screw in inlet aswell
DO NOT touch the idle screw, wont be that if its just started doin it.
just check tps and clean icv.
also check if your dizzy is loose
  On 8/17/2013 at 12:13 AM, TurboTobz said:
What's unsafe about the idle screw?
now your splittin hairs.
check the more obvious things before goin for the screw because if he does the screw first, then the others without checkin with the engine on for example and the problems still there when he does turn her over, hws he gona know if hes got it?
u get me?
  On 8/17/2013 at 12:59 AM, TurboTobz said:
Not since you were having troubles, you got it sussed now right?
lol nope. but il tell u sumthin, standin behind it, hearin the Fujitsubo.........my fuckin god! any vid I've seen of 1s only been runnin a ct9.....this with a TD04 n 5efhe cams sounds utterly sexual and throaty! soo powerful soundin, its amazin! Dyin for its first drive mate, seriously chokin for it
