PaulStarletSR Posted August 17, 2013 Share Posted August 17, 2013 I've got it set to 4e but is this correct? just another thing i was thinkin of to try eliminate my engine rev issue...........opinions plz? Quote Link to post Share on other sites
PaulStarletSR Posted August 17, 2013 Author Share Posted August 17, 2013 bump! need to know this please Quote Link to post Share on other sites
PaulStarletSR Posted August 17, 2013 Author Share Posted August 17, 2013 when set to 4e with 5efhe cams, will this make the revs go up and down at all? Quote Link to post Share on other sites
AdamB Posted August 17, 2013 Share Posted August 17, 2013 Should be set to 5E mate, that's the way I figure it anyway. The cam specs are different, therefore should be set to the 5E mark. Saying that when changing cams they should be dialed in with a DTI if you want it accurately done. Quote Link to post Share on other sites
PaulStarletSR Posted August 17, 2013 Author Share Posted August 17, 2013 so the fact I've got them set to 4E be makin it fluctuate in revs? cause STILL when i cover the throttle body it doesnt cut out and ALL the vac pipes have been triple checked and are fine :-( Quote Link to post Share on other sites
AdamB Posted August 17, 2013 Share Posted August 17, 2013 (edited) It will most likely run slightly lumpy, possibly the rev's will alternate ever so slightly. Edited August 17, 2013 by AdamB Quote Link to post Share on other sites
PaulStarletSR Posted August 17, 2013 Author Share Posted August 17, 2013 yip, thats what its doin. il try flickin it to 5e n see if it improves any later Quote Link to post Share on other sites
AdamB Posted August 17, 2013 Share Posted August 17, 2013 Let us know pal. What TB are you using as well? FTE one? Have you tried checking the wax stat is operating correctly? Quote Link to post Share on other sites
PaulStarletSR Posted August 17, 2013 Author Share Posted August 17, 2013 Let us know pal. What TB are you using as well? FTE one? Have you tried checking the wax stat is operating correctly? aye mate, fte 1, I've done the whole fte conversion. wax stat? :-/ Quote Link to post Share on other sites
AdamB Posted August 17, 2013 Share Posted August 17, 2013 (edited) Yeah there's a wax stat on the TB which allows air to bypass to the ICV I believe. Edit.More info herehttp://www.toyotagtturbo.com/forums/showthread.php?102783-Wax-Stat-help&highlight=stat http://www.toyotagtturbo.com/forums/showthread.php?102228-When-you-think-your-getting-somewhere!!!&highlight=stat Edited August 17, 2013 by AdamB Quote Link to post Share on other sites
PaulStarletSR Posted August 17, 2013 Author Share Posted August 17, 2013 not sure of this but i cleaned all the crap out the icv n there was no change Quote Link to post Share on other sites
AdamB Posted August 17, 2013 Share Posted August 17, 2013 It's not the ICV, theres a wax stat in the TB, hence why there is water pipes going to it. Quote Link to post Share on other sites
turbo Grant Posted August 17, 2013 Share Posted August 17, 2013 It is an idle control valve in the tb. That one on the end of the manifold people go on about does f all from experience. Quote Link to post Share on other sites
PaulStarletSR Posted August 17, 2013 Author Share Posted August 17, 2013 It is an idle control valve in the tb. That one on the end of the manifold people go on about does f all from experience. what do u think about the 4e 5e settins for the cams? could it be causin my probs if set wrong? Quote Link to post Share on other sites
turbo Grant Posted August 17, 2013 Share Posted August 17, 2013 I wouldn't have thought it would cause the idle to fluctuate. Do you have the filter/ damper in the map sensor pipe? And when the wax stat in the tb goes that usually give you a high and annoying idle. You got the temp sensor sorted? You could just be getting a bit of a lean missfire Quote Link to post Share on other sites
PaulStarletSR Posted August 17, 2013 Author Share Posted August 17, 2013 well its not been startd up since the sensor was put in so wel find out today/2moz Quote Link to post Share on other sites
turbo Grant Posted August 17, 2013 Share Posted August 17, 2013 I would laugh if its ok when you start it up Quote Link to post Share on other sites
PaulStarletSR Posted August 17, 2013 Author Share Posted August 17, 2013 I would laugh if its ok when you start it up i would cry tbh lol but how would puttin in a sensor be the answer to me bein able to completely cover the throttlebody and it not cut out? :-( Quote Link to post Share on other sites
