The first gen were poor, 2nd gen were better and people seem to be happy with them.
Whats your engine spec? Most people don't even need cams, or choose them for the wrong reasons.
forged 4e, greedy td05 14b, not fully spooled till 5,000rpm its laggy and needs cams and valve springs, want some cams to build a head up to kill some lag.
You'll need cams with shorter duration and a wider LSA then. You'll be better off getting some from Tighe as they have a load of "off the shelf" specs available, ranging from 80 degrees, all the way upto 340.
Something around 215-225 degrees duration, 8.2mm lift and an LSA of 114 degrees.
dude, what are you studing or been studing you know some stuff
stock cams will do 350-370bhp+ easily...
Spend your money on a billet wheel or dual ball bearing turbo, or a decent boost controller. If you want better spool!
where your proof lol, only kidding its true tho and socks got good spool
Stock cams are fine, but the guy isn't looking for power, he asked how he can improve his low-mid range torque. Besides billet cams can be had cheap if you know where to look :thumbsup:
Edited by AdamB
They will be fantastic quality products too lol
