russ78 Posted August 23, 2013 Share Posted August 23, 2013 (edited) so I forged my engine and ive had numorous minor issues which all have been resolved,but i went for a spirited drive for about 15 mins tonight and started over heating shes had a new thermostat a new civic rad and fan plus new coolant. but when I built it I noticed that the new toyota water pump didn't seem to spin very freely I just put it down to being new but now im wondering if this is my problem I guess there could maybe be a little air still in the system anyone have any suggestions as im kinda scratching my head now Edited August 29, 2013 by russ78 Quote Link to post Share on other sites
TurboTobz Posted August 23, 2013 Share Posted August 23, 2013 Is the cooling system pressurising? Could well be air lockAre you getting hot air through the heaters? Quote Link to post Share on other sites
russ78 Posted August 23, 2013 Author Share Posted August 23, 2013 didn't try that bud ill check Quote Link to post Share on other sites
mattglanza79 Posted August 23, 2013 Share Posted August 23, 2013 Are both hoses getting hot. Remove thermostat and check to see if operating. Failing that could have a air lock. Most water pumps I've ever used on various cars trucks spin free tbh Quote Link to post Share on other sites
russ78 Posted August 23, 2013 Author Share Posted August 23, 2013 ok checked heater its running hot on hot and cold on cold ??? Quote Link to post Share on other sites
russ78 Posted August 23, 2013 Author Share Posted August 23, 2013 Are both hoses getting hot. Remove thermostat and check to see if operating. Failing that could have a air lock. Most water pumps I've ever used on various cars trucks spin free tbh both hoses are getting hot yeah, the water pump I would say had resistance didn't spin freely Quote Link to post Share on other sites
mikey4410 Posted August 23, 2013 Share Posted August 23, 2013 surely that indicates the pumps functioning and waters going round Quote Link to post Share on other sites
russ78 Posted August 23, 2013 Author Share Posted August 23, 2013 (edited) surely that indicates the pumps functioning and waters going round yeah mikey it does but what does that leave ??? fan works as it should new rad, new thermostat, new coolant, new water pump heater blows hot and cold fine ? im confused Edited August 23, 2013 by russ78 Quote Link to post Share on other sites
Danza V Posted August 23, 2013 Share Posted August 23, 2013 (edited) Did you say you bled the system again? The heater pipes one off the thermo housing if I'm correct? So, just because there's heat doesn't mean the pums working, correct me if I'm wrong though. Could be that the pumps struggling to pump it round. I'd probably check the pump tbf mate ( pain on these. With the engine in ) Edited August 23, 2013 by Danza V Quote Link to post Share on other sites
russ78 Posted August 23, 2013 Author Share Posted August 23, 2013 Did you say you bled the system again? The heater pipes one off the thermo housing if I'm correct? So, just because there's heat doesn't mean the pums working, correct me if I'm wrong though. Could be that the pumps struggling to pump it round that's what im thinking, might be pumps struggling to push it round but no way to test it is there ? Quote Link to post Share on other sites
Danza V Posted August 23, 2013 Share Posted August 23, 2013 (edited) Well, you could try to get down there, remove the belt and spin it, if its still tight then it's possibly that.. Should spin nice and smooth. Is like making a noise or anything? Edited August 23, 2013 by Danza V Quote Link to post Share on other sites
russ78 Posted August 23, 2013 Author Share Posted August 23, 2013 don't think it does, as I remember it had a little resistance I just thought that was normal as it needs to wear but guess not Quote Link to post Share on other sites
TurboTobz Posted August 23, 2013 Share Posted August 23, 2013 Generally speaking you won't get hot air if it's thermostat. Did you check the If it's pressurising the system?Take the rad cap off and rev the car does the coolant level rise as the revs get higher? Quote Link to post Share on other sites
russ78 Posted August 23, 2013 Author Share Posted August 23, 2013 Generally speaking you won't get hot air if it's thermostat. Did you check the If it's pressurising the system?Take the rad cap off and rev the car does the coolant level rise as the revs get higher? yes mate coolant levels rise as revs get higher Quote Link to post Share on other sites
Danza V Posted August 23, 2013 Share Posted August 23, 2013 Id be tempted to check the pump mate. Quote Link to post Share on other sites
russ78 Posted August 23, 2013 Author Share Posted August 23, 2013 yeah gonna do a compression test to eliminate all possibilitys as well but im edging towards water pump Quote Link to post Share on other sites
TurboTobz Posted August 23, 2013 Share Posted August 23, 2013 Any pressure in that rad? Top or bottom hose getting hard? Hissing when undoing cap? Spitting any coolant? Quote Link to post Share on other sites
russ78 Posted August 23, 2013 Author Share Posted August 23, 2013 yeah hoses getting hard mate, do you mean undo the cap after its been running r u serious ? Quote Link to post Share on other sites
AdamB Posted August 23, 2013 Share Posted August 23, 2013 Might sound stupid but is air able to get get to the radiator core? Quote Link to post Share on other sites
TurboTobz Posted August 23, 2013 Share Posted August 23, 2013 yeah hoses getting hard mate, do you mean undo the cap after its been running r u serious ?Usually safe to release it, and it will depressurise itself but I would Definately reccomend a towel wrapped up to cover anything it may chuck out.If there getting hard I'd expect it may want to gush out water. In which case you maybe looking at a headgasket failure or similar Quote Link to post Share on other sites
russ78 Posted August 23, 2013 Author Share Posted August 23, 2013 im gonna compression test as soon as possible so this is indicate or eliminate hg Quote Link to post Share on other sites
Danza V Posted August 23, 2013 Share Posted August 23, 2013 Silly me, I never thought about the possibilities of it being the hg. Lol Quote Link to post Share on other sites
jayc-glanza17 Posted August 23, 2013 Share Posted August 23, 2013 by overheating...is this a accurate gauge reading? or the stock temp gauge you are going by??? also did it cool down when u stopped driving spiritedly?? Quote Link to post Share on other sites
russ78 Posted August 23, 2013 Author Share Posted August 23, 2013 Not really sure why it would be hg though as head and block were skimmed block was decked as well and a new Athena 1.2 hg used but stranger things have happened Quote Link to post Share on other sites
russ78 Posted August 23, 2013 Author Share Posted August 23, 2013 by overheating...is this a accurate gauge reading? or the stock temp gauge you are going by??? also did it cool down when u stopped driving spiritedly?? yeah cooled down when stationary jay and no I have aftermarket water temp gauge as well Quote Link to post Share on other sites
