russ78 Posted August 29, 2013 Author Posted August 29, 2013 cheers craig luckily enough I have another head gotta get it pressure tested first make sure its tip top and a new HG but at least I have a definitive answer Quote
russ78 Posted August 29, 2013 Author Posted August 29, 2013 im guessing it must be a hairline crack in the head as I don't get bubbles like that when its cold nor the crap compression results ? Quote
Taggy Posted August 29, 2013 Posted August 29, 2013 (edited) All those bubbles will no doubt be compression leaking into the rad system, which is why its overheating, still a fucker though!! Could still be just a dodgy HG, but i would change the head to be sure, just make sure you get it skimmed. Did you get the block decked? Edited August 29, 2013 by Taggy Quote
russ78 Posted August 29, 2013 Author Posted August 29, 2013 (edited) yeah mate block was decked and head was skimmed Edited August 29, 2013 by russ78 Quote
mikey4410 Posted August 29, 2013 Posted August 29, 2013 Soooooooo sorry to hear of this matey.if i can assist in any way please dont hesistate to call or message me. Quote
Taggy Posted August 29, 2013 Posted August 29, 2013 just out of curiosity was this head ok before you had it forged? Quote
mikey4410 Posted August 29, 2013 Posted August 29, 2013 I thought that aswell.meant to ask.maybe its just a headgasket that hasnt been dun up correct( no offence russ) or reused headbolts? Just throwing ideas out there as to why this has happened. Quote
Taggy Posted August 29, 2013 Posted August 29, 2013 i would say its unlikely to be a cracked head if it was ok before, its much more likely to be a duff HG, in any case you will know once you take the HG off, if its not obvious then get the head tested at your local machine shop or just stick the other head on Quote
mikey4410 Posted August 29, 2013 Posted August 29, 2013 Im sure russ used an athena gasket though,very high quality and all that. Quote
russ78 Posted August 29, 2013 Author Posted August 29, 2013 Im sure russ used an athena gasket though,very high quality and all that. yeah bud Athena 1.2 head gasket used and ARP head Bolts head and block were skimmed and decked but I didnt have the head pressure tested and it wasn't my head was one I bought off someone off the forum oh well lesson learnt I guess Quote
jayc-glanza17 Posted August 29, 2013 Posted August 29, 2013 its gases in coolant, so head or hg, personally is get a block test done, to see what shows up.. what has jake said about the head russ?? Quote
TurboTobz Posted August 29, 2013 Posted August 29, 2013 If you get stuck I have what looks to be a perfect head in my garage, and will be up your area on weekend no doubt. Quote
