loguey Posted August 27, 2013 Posted August 27, 2013 Bought myself 106 diesel as a little runabout so I can fix my sr up. Needs a new indicator stalk so I've stripped the steering column down and now it wont start. Now I kno some pugs/citroens have like an immobiliser receiver near the ignition barrel but mine has the keypad immobiliser so cant imagine it has it by the ignition? If its not that where can I start looking for the issue? I need to get a few bits to get it through the mot but if its gonna cost me a bomb im not gonna bother and ill just fill it with scrap metal and weigh it in, which I dont particually want to do as 50mpgs+ sounds appealing!! Quote
Billy SR Posted August 27, 2013 Posted August 27, 2013 (edited) should probably ask over on retrorides or autoshite. mum had one back in the day and did 150k trouble free miles until it needed scrapping because of rust. mpg is amazing! Edited August 27, 2013 by Billy SR Quote
StuDoc 72 Posted August 28, 2013 Posted August 28, 2013 Until the bearings go in the rear arm and you are riding in what is essentially a French wheel barrel Hope you find the problem mate. Quote
Addymk2 Posted August 28, 2013 Posted August 28, 2013 You getting any power with the key in? I.e dash lighting up etc. Could have just knocked a cable out tbh. Quote
loguey Posted August 28, 2013 Author Posted August 28, 2013 Yeah its turning over but showing no signs of life. Rbz, every time i turn the key and it doesnt fire its gettin one step closer to being weighed in. Quote
jellybaby Posted August 28, 2013 Posted August 28, 2013 I was a Peugeot master tec Sounds like you have dislodged a plug or maybe a wire best bet is to disconnect the bat for 10 mins then enter ya code once reconnected try that if Dont work pm me and I c what I can do Quote
loguey Posted August 28, 2013 Author Posted August 28, 2013 Cheers. I plugged the old indicator back in and checked around where I've been fettling for loose plugs/wires but not spotted anything yet. will try disconnecting the battery for a while and try again. Quote
