Ep'd Posted August 29, 2013 Posted August 29, 2013 I posted it in the technical section but my post got deleted so here it is.I took off my airbag steering wheel and replaced it with an aftermarket boss and wheel. I can live with out the automatic indicator cancelling but...Could someone please tell me how to wire the horn on the aftermarket wheel. Where do the connections on the horn push go to?Any pics or suggestions would be appreciated Quote
1991 starlet owner Posted August 29, 2013 Posted August 29, 2013 What make is the aftermarket kit bud?? Quote
Ep'd Posted August 29, 2013 Author Posted August 29, 2013 It's a omp steering wheel and just a normal eBay special boss mate Quote
1991 starlet owner Posted August 29, 2013 Posted August 29, 2013 Hmm that's funny because its the same one I've got! I didn't have a problem with mine. Just fitted straight in my ep82. Anychance you could pop a photo up of the wires you mean??If I get a chance I'll whip mine off and remind myself (as I fitted it well over a year ago).Sorry I can't be more helpful straight away!Tom. Quote
Ep'd Posted August 29, 2013 Author Posted August 29, 2013 (edited) It's one like this mate but mine has no wire in it like that pic?http://bit.ly/100QhL3Thanks any help is appreciated Edited August 29, 2013 by Ep'd Quote
1991 starlet owner Posted August 29, 2013 Posted August 29, 2013 So there's no wire from the steering column? How did your standard steering wheel make the connection mate?? Tom. Quote
Ep'd Posted August 30, 2013 Author Posted August 30, 2013 It had a ring metal earth piece on the steering wheel that is fixed to the back of the original steering wheel and where the horn goes it's all wired inside the steering wheel on the airbag type if that makes any sense. The wiring and the earth are built into the airbag steering wheel.I might have to solder a wire onto the boss or simply wire the horn to a push button Quote
Spoon_tuned Posted August 30, 2013 Posted August 30, 2013 You should have 2 wires put one wire behind where the allen key nuts go in use as an earth Quote
