Item For Sale:
ARC intercooler
Item Condition & Description:
This is a genuine cooler, and makes a great upgrade for the standard top mounted interwarmer. There are a few bent fins from where it has touched the inlet manifold but they do not affect its operation in any way. It holds pressure great. I was seeing 0.9 bar. As the casting on these is a little rough, it has been sanded to smooth it and I have painted the end tanks with very fine aluminium paint which improves how it looks but do not affect its efficiency.
Includes the silicon joiners I was using.
The front brackets have been professionally Ali welded to improve strength.
I've had the bend that had been cut professionally ally welded by the same guys that reinforced the front brackets. They pressure tested it for me and there are no leaks.
It is now almost as good as new, save for a few bent fins.
I've put a couple of new pics in.
Price:
£120 inc postage to mainland UK.
1FDA50F5-68EF-4E39-95EE-6402775C19FF-637
9BE8AAF2-3DB6-45D1-A06E-9004454CA692-637
1F55EBAC-55FD-475B-A82B-3A312506FB80-241
B9450915-889C-4F01-9F67-7350B75373AE-241
F740B086-1000-46B8-B674-E270E89961BA-241
Payment & Shipping Details:
PayPal use please add 4%.
Postage to other areas can be arranged at buyers expense.
Monster Motorsport 2 gauge 60mm pillar pod.
Item is in good condition. Painted currently in grey primer to match 98 spec interior. Two small holes near top for alarm sensor. Very slight crack in gel coat near top.
Price:
£20
Pictures
113BAA96-CF99-43E4-9F35-B31232A4E3BA-637
Payment and shipping
£7 postage
if using PayPal add 4% to total price.
All items all located in Bedfordshire.
Thanks for looking
Edited by Mr. Chem
Whoa that ARC cooler is stupid cheap. These are very underrated these days and cut lag compared to a front mount and flow well enough for a TD04 running 1.0 bar boost. It also fits the standard mounts and can be fitted in under 5 minutes.
I can't believe this didn't sell in seconds.
Is it the one I sold you? (Arc)
If so I still have the pressure test pictures I took for you
Ryan
Yeah its your one buddy.
If you could post those photos buddy that would be great
Do you still have the pod holder mate
I do
  • 2 weeks later...
  • 1 month later...
