jellybaby Posted September 1, 2013 Share Posted September 1, 2013 hello all I will soon to be running a oil cooler kit with a built in thermostat etc the normal amount for these engines is about 4-4.5 liters I think ???? should I add a bit more due to the fact if the oil is cooler then the stat what ever is left in the cooler is basicily in the cooler pipes ???? then would effect the oil level etc I just don't want to spin a shell etc with losing oil Quote Link to post Share on other sites
StarletSr? Posted September 1, 2013 Share Posted September 1, 2013 You should add more yes but i thought theses engines only take about 3 liters anyways? Quote Link to post Share on other sites
jayc-glanza17 Posted September 1, 2013 Share Posted September 1, 2013 yes u do..and 2.8 to 3 litres is maximum oil..so add whatever in millilitres you cooler takes.. personally, fill to cooler to brim, connect oil lines and fill as you normally would do. Quote Link to post Share on other sites
jellybaby Posted September 1, 2013 Author Share Posted September 1, 2013 cheers guys i bear that in mind when i finaly get round to putting it all together etc think i might add half liter more then standed Quote Link to post Share on other sites
jayc-glanza17 Posted September 1, 2013 Share Posted September 1, 2013 no mate..fill cooler up first with oil, connect oil lines, then fill up to dipstick level..its all dependant on what capacity your cooler can take. Quote Link to post Share on other sites
jellybaby Posted September 1, 2013 Author Share Posted September 1, 2013 (edited) no mate..fill cooler up first with oil, connect oil lines, then fill up to dipstick level..its all dependant on what capacity your cooler can take.Ah ok feller will do cheers Edited September 1, 2013 by jellybaby Quote Link to post Share on other sites
jayc-glanza17 Posted September 1, 2013 Share Posted September 1, 2013 when you fitting it?what oil cooler kit you got? Quote Link to post Share on other sites
AdamB Posted September 1, 2013 Share Posted September 1, 2013 yes u do.. and 2.8 to 3 litres is maximum oil.. so add whatever in millilitres you cooler takes.. personally, fill to cooler to brim, connect oil lines and fill as you normally would do. This! Or you'll be replacing crank seals lol. Quote Link to post Share on other sites
jellybaby Posted September 1, 2013 Author Share Posted September 1, 2013 when you fitting it?what oil cooler kit you got?Be fitted in the next few weeks feller and it a Gready one grex kit with relocation kit as well Quote Link to post Share on other sites
