hello all I will soon to be running a oil cooler kit with a built in thermostat etc
the normal amount for these engines is about 4-4.5 liters I think ????
should I add a bit more due to the fact if the oil is cooler then the stat what ever is left in the cooler is basicily in the cooler pipes ???? then would effect the oil level etc I just don't want to spin a shell etc with losing oil
no mate..
fill cooler up first with oil, connect oil lines, then fill up to dipstick level..
its all dependant on what capacity your cooler can take.
Ah ok feller will do cheers Edited by jellybaby
yes u do..
and 2.8 to 3 litres is maximum oil..
so add whatever in millilitres you cooler takes..
personally, fill to cooler to brim, connect oil lines and fill as you normally would do.
This! Or you'll be replacing crank seals lol.
