Hiya guys
Now when boosting over 0.5 bar of boost my car starts stuttering and feels like I'm hittin 5 bricks walls
I know this isn't right
When I bought the car I was its because I need to set up my apexi safc 2 ? But I have no clue
Anyone help me ?
I would take that apexi out for now you won't need it just yet if your running stock boost clean those spark plugs check the dizzy cap look at all the basics first imo
Its not running stock boost, boost goes up to 0.9 bar before I'm hittin a brick wall but boosts at 0.5 bar fine
I might just stick the car into my local tuning shop Nd get them to do it ha, I can turn the boost down but don't know which way to turn the twisty thingy hAhha
I would do this, the reason it's jolting is because its trying to go past 0.85 boost, this is when fuel is cut to protect the engine. Turn boost down.
Edited by Sefton-EP91
On my old boost conroller u had to undo it to reduce boost ,but do ureslf a favour and get standard high/lo solenoid back on it as its better at controlling boost.until such time u can get a edc mate.
Its the safc. Remove it and get some management on there. The safc is lying to the ecu telling it that more pressure than is actually in there. Hence adding more fuel but causing fuel cut.
Nope all they do is raise or lower the voltage at certain rpm points. Plus they need a 0-5v sensor reading from the tps as it has a high and a low ''map'' if you want to call it that. Our starlets do not use a 0-5v sensor for the tps unless you have a auto tps. Hence why the emb doesnt have the grey (i think) tps wire wired in.
