(NAS) starlet ep82 Posted September 4, 2013 Posted September 4, 2013 Hi guysMy last issue with the car is that -I have a LOUD clicking/clunk noise from when turning right & left in full lockJust to give u an idea Sounds abit like the wheels are scraping on plastic arch liners BUT its notI know it sounds like cv joints but i've changed the driverside cv joint but still the same noise in full lock both sides Absolutely puzzles to what it can beHad the both drive shafts out today & inspected them & thre all fineWhat can it possible be ? :-/Car was fine before tuck off road 1 year ago since then had engine & suspension out n refitted it all recently Only other think i know it needs tracking too as fittef track rod ends etc Quote
akyakapotter Posted September 4, 2013 Posted September 4, 2013 i know you said you have checked the drive shafts but have you checked the cv joints. Sound you are describing sound to me like the cv joints have had there day.cheers nick Quote
(NAS) starlet ep82 Posted September 4, 2013 Author Posted September 4, 2013 Hi Cv joints one is brand new fitted last week & the other is 1 year oldHad the shafts out today to inspect & thre all perfectly fine Car was spot on before it went off road 1 year ago & since then been on axle stands removed engine etc& i have BC coilovers so springs are seated proplyBeen on it all day today but still same problem when full lockingHad the track rod ends changed so tracking is out too n tht about it Quote
yaristurbo Posted September 4, 2013 Posted September 4, 2013 how old are the bc's top bearings? nothings catching with it beeing low? brake disc back plate when bearings got weight load on it? stone in caliper? Quote
Addymk2 Posted September 4, 2013 Posted September 4, 2013 Have ou got access to a pit? or a set of ramps you could drive the car up and get under neath? Or even a really high kerb then just hang off various components until the sounds replicated. Quote
(NAS) starlet ep82 Posted September 4, 2013 Author Posted September 4, 2013 Coilovers are only a year old its defo not from the suspension side of things It only does it on quick turns & full lock Dont want to order another CV joint & find out its not that again as replaced the driver side joint last weekPlus i had the shafts out last night & inspected them & the cv joints Quote
(NAS) starlet ep82 Posted September 4, 2013 Author Posted September 4, 2013 Front brake disc heat shields are removed off the car because we thought it was only tha but NO Reli neee to get this sorted now as this is the only last issue left on the car till it finally comes out to play after a year Quote
hamish Posted September 4, 2013 Posted September 4, 2013 I had a really bad 'Clicking' when on full lock both way's, replaced both cv joints and solved my problem. Quote
(NAS) starlet ep82 Posted September 4, 2013 Author Posted September 4, 2013 I had a really bad 'Clicking' when on full lock both way's, replaced both cv joints and solved my problem.Yeaah i've changed the driverside one but left hand side clunk has always been there because of my cusco LSD Just not sure what to do or where to start with it todayIts a shame tho as its only last issue before its proply on the road Anyone else know what it can be ? Quote
1991 starlet owner Posted September 4, 2013 Posted September 4, 2013 Perhaps replace the other cv joint?Tom. Quote
(NAS) starlet ep82 Posted September 4, 2013 Author Posted September 4, 2013 Yeaah thts the next thing to do replace other joint too BUT thts only a year old & the noise us fr both sides when turning full lock the more i turn the more louder it gets :'(Hate the car & confused as to what it can possibly be ite strange Quote
1991 starlet owner Posted September 4, 2013 Posted September 4, 2013 Mmmm.. I would just mentally break it all down. Think about everything it could be, and then think outside the box too. However confused you are remember that something is wrong. There's a component somewhere that's not ringing true. Thomas Edison tried and tested over 200 ways to create the incandescent light bulb fillamant. And when asked about his failure he replied:I didn't fail, I found out over 200 ways how not to create a lightbulb. I only have to find one way to make it work.Don't loose faith buddy!Tom. Quote
