Cheznutter Posted September 16, 2013 Posted September 16, 2013 (edited) carrying on from my earlier question regarding my turbo instilation, which i am currently doing, both the lines coming from the engine to the turbo ..which way round do they go ? does it matter ? any help would be great asbim no mechanic:) Edited September 16, 2013 by Cheznutter Quote
Glanza-Ben Posted September 16, 2013 Posted September 16, 2013 Just re fit it like you took it off and make sure all nuts and bolts are tight with new gaskets and check the oil and water lines ain't leaking on 1st start up n it will be fine Quote
turbo Grant Posted September 16, 2013 Posted September 16, 2013 Would be a good idea to prime the turbo before starting. Pull the king lead off crank the engine till you have oil running out the return and your good to fire up Quote
mikey4410 Posted September 16, 2013 Posted September 16, 2013 What grant said is a bloody good idea. Quote
Cheznutter Posted September 16, 2013 Author Posted September 16, 2013 Would be a good idea to prime the turbo before starting. Pull the king lead off crank the engine till you have oil running out the return and your good to fire upI knew I read somthing years ago about this thanks man Quote
Cheznutter Posted September 16, 2013 Author Posted September 16, 2013 wouldnt oil be spilling out of the sump though ? Quote
StuDoc 72 Posted September 16, 2013 Posted September 16, 2013 It will come out of the return pipe (the rubber hose which goes from the bottom of the turbo into the sump. If you lie on the ground while someone turns it over give them a shout to stop turning it over as soon as oil comes out youd be unlucky to lose 100ml. Quote
RobSR Posted September 16, 2013 Posted September 16, 2013 (edited) Like said prime it, dont just start it up! Oil wont come out the sump if you take the turbo oil return off, as its above the level. Wait till it drips out the bottom of the return and refit and start. I prime by removing the efi fuse aswell, as just removing the king lead still dumps fuel in. Edited September 16, 2013 by RobSR Quote
Cheznutter Posted September 16, 2013 Author Posted September 16, 2013 all very helpful thanks guys . Quote
