Failed mot, need help
Me Glanza failed mot today, on number plate bulb as ones not very bright, headlight adjustment and no horn (I did try to blag that) but now I can't find my horn wiring to fit a switch I stripped the steering Column down but not a clue where it's to any one care to help with its location, Cheers
  On 9/18/2013 at 2:12 PM, Glanza-Ben said:
I got the horn side but the steering wheel side had vanished it was there once when I had normal steering wheel lol the original one is a plug but can't source where it goes
I'm in the same boat
Na they ain't there I stripped the whole lot down last night and ain't got a clue the original horn is on a white plug but can't find where that ifs into on the column I would trace it back from the front but was hoping some one could shed some light the worse case is I spend a hour putting my own wiring from horn to dash tonight
On the original steering wheel (I had the airbag type) the horn wires are built into it. So when removed the wires went with the steering wheel. Sounds weird but true!
So I think the bolts that hold the original steering wheel in place are some how earth and positive when bolted in
Edited by Ep'd
This is all that's there behind my plastics
8A291C62-8C4A-4F5A-A6A6-B338F57196C1-140
But the plug for horn don't fit them but saying what your saying I think mine was similar but I've lost the ring thing that went on Aswell for the airbag
