Chops Posted October 14, 2013 Share Posted October 14, 2013 Hey all, planning to swap my turbo and manifold out soon, and have most of the bits i need ready. I was wondering though, is it ok to reuse the origingal turbo to downpipe gasket, or should i replace it? the turbo is is identical across that face, so it shouldnt be an issure, right? also, im having trouble finding the turbo to intercooler gasket, it seems to be the same as an external wastegate gasket but im not sure. any help appreciated! Quote Link to post Share on other sites
Ollieh17 Posted October 14, 2013 Share Posted October 14, 2013 I thought the same about the external wastegate gasket. This is the one you need http://www.id-workz.co.uk/index.php?main_page=product_info&cPath=3_1118_8_102&products_id=4695 Quote Link to post Share on other sites
RobSR Posted October 14, 2013 Share Posted October 14, 2013 You can get away with reusing the turbo > decat one if its not screwed, just make sure you change the head > manifold one if you take it off. Quote Link to post Share on other sites
RobSR Posted October 14, 2013 Share Posted October 14, 2013 This is the part number from toyota for the IC pipe gasket - 17277-11020 Quote Link to post Share on other sites
mikey4410 Posted October 14, 2013 Share Posted October 14, 2013 u can reuse turbo gaskets over and over no problems. Quote Link to post Share on other sites
Chops Posted October 14, 2013 Author Share Posted October 14, 2013 thanks fro the fast response guys, cleared that all up fast lol! Quote Link to post Share on other sites
Idrees Posted October 14, 2013 Share Posted October 14, 2013 On 10/14/2013 at 9:27 AM, mikey4410 said: u can reuse turbo gaskets over and over no problems. I've seen many that crack. If they've never been replaced before I would guess they'll split/crack when removed, but of course that isn't always the case. Quote Link to post Share on other sites
