hey thank you for looking :), I have recently brought and fitted a new zisco ram horn manifold (externally gated) hybrid turbo new water lines extrrnal waste gate ive given ot a service ive fitted a two silicone pipes from the wastegate one to the inlet manifold and one to the turbo I guess I still need a dump valve ? the silicone pipe from the top of the wastegate goes to the inlet mani and the bottom one goes to the turbo this right ? if I do still need a dump valve how does the piping work do I leave or blank any off ? or get splitters as I know the inlet mani needs to be plumed into the dump valve? any help would be great thanks in advance :) .
When using an EWG with no EBC you connect a vacuum line from the turbo to the EWG, leave the other port (on top of the wastegate) to atmosphere. Then the spring inside the EWG controls the boost. And just leave your DV line connected to the inlet as it was before.
Hope that makes sense lol.
One from the side port on the wastegate to a vacuum source so either the turbo or Inlet manifold. From the turbo is better. Leave the top port open if your not using a boost controller.
Put the vac from the dump valve to a vacuum source also like the inlet.
Ah dan beat me too it!
Edited by RobSR
oh mate saviour :) I was doing my nut in earlier :) where abouts do I have my dump valve positioned I was going to cut a section out of the intercooler piping and get one of those inserts or is there a easier better more cost effective way ? thanks for your help man.
thanks anyway man :)
If you have nothing for it then yeah put a bit of vac pipe over the nipple on the inlet, and put a bolt through that with a jubilee to hold it air tight.
