AndyT Posted December 11, 2005 Posted December 11, 2005 Hi im new, i have a CRX Vtec and soon to own a EP82 GT turbo.I have had a good search on your forum and have found some very useful info with regards to FMIC and exhausts Im just wondering are there any brakes off another toyota or other car that are a direct replacement for the EP82 brakes but bigger? Will the master cylinder need upgrading?Just thought i would enlighten you on my plans for the car :Fully stripped including any sound deadeningWERP 2.5inch turbo back systemFMICEither piggyback ecu or Boost cut controllerBigger brakesSmaller wheels (has 16's atm)Small shot of nitrousIt already has an HKS actuator and damping adustable suspensionAre there any other say fuel or engine modifications i would need to get the car to run safely at around 180bhp (without nitrous)? Quote
Simon Posted December 11, 2005 Posted December 11, 2005 Are you talking 180bhp at the fly or wheels?You will need some sort of fuel controller for that kind if figure the CT9 will be right on it's upper limits to achive that figure anyways you might be best looking at the TD04 route.Simon Quote
AndyT Posted December 11, 2005 Author Posted December 11, 2005 Simon - im looking for around 180 at the flywheelJaystar - Im pretty new to starlets and dont have much idea of what the OEM fuel system is capable of? Is it not just a case of remapping/piggyback (apexi)? OR will bigger injectors/fuel pump be needed?I was thinking of being a bit cheap and using a RRFPR and setting it up using wideband but would this work with the rest of the fuel system being stock? Quote
*Toymota* Posted December 11, 2005 Posted December 11, 2005 talkin about brakes, does anyone else find the brakes on the SR really crap?(sorry for hijackin the post) lol Quote
AndyT Posted December 11, 2005 Author Posted December 11, 2005 The stock setup will fuel cut at 1 bar of boost as a safety parameter. This being said it's still not safe to 'bounce' off fuelcut. Easy option is an aftermarket ECU which will adjust everything to suit. Basically plug and play although price may be a factor.The cheaper option of fitting a RRFR, fuelcut defender and possibly an upgraded fuel pump is the more common route although reliability is all in the tune. Would involve more roller time but don't let this put you off.<{POST_SNAPBACK}>What kind of aftermarket ECU's are just plug and play then? Do you just predefine a AFR then and it maps itself? rough price? (i will probably cry when i see the price) I kind of realised it wasnt safe to keep on hitting the fuel cut as it must make the car run lean for that little period of time?cheers for the help Quote
Simon Posted December 11, 2005 Posted December 11, 2005 What Jay has said is good advise the tock manifold is pants.As for the FCD v ECU it all depends on how far you plan to take your tune for what you are after 189 @ fly an FCD and fuel preuure regulator "should" be ok. If you want to go further then an upgraded fuel pump and some 330 or even 440cc injectors might be needed.Simon Quote
AndyT Posted December 11, 2005 Author Posted December 11, 2005 Alright thanks lads!Any reccomendations on what pads and disks to upgrade to? Quote
Ryno Posted December 11, 2005 Posted December 11, 2005 well i'm after a set of 3G Disks and some Endless pads, as far as i've seen Envy is the best company to get them from!check out their bit in the traders section of TGTT.com Quote
Simon Posted December 11, 2005 Posted December 11, 2005 Depends how far you want to go my setup is:Cusco master cylinder braceAPP stainless brake linesStd rear discs with project mu padsLevin 2 pot front calipersCorolla discs 5mm thicker than stockEBC red stuff padsSimon Quote
