i do think so although some of the configurations are different.
on the gts the brake caliper carrier is on the caliper.
have seen a glanza one recently for first time and the caliper carrier was built into hub..
dont think that should hinder you that much though as i think they still line up brake caliper wise,but dont quote me on that
Late gts are the same, glanza and late gt brakes are the same too. Carrier is removable on both cars. (not sure what you were looking at mikey?)
Only thing that changes and it doesn't seem to be year specific is the spline count for the cv joint, that will need to be the same as your driveshafts.
early model gt's have a 54mm centerbore where the disc locates whereas later gt's and glanzas have 55mm centerbore then it steps down to a 54mm where the wheel locates
Edited by morgey
