Hi,
I have measured fuel pressure with stock FPR and standard fuel pump.
Results (@ inlet preasure -> fuel pressure):
@ 0 bar (engine off, fuel pump running) -> ~3 bar
@ -0.7 bar (idlling) -> ~2.4 bar
@ +0.7 bar (on boost) -> ~3.3 bar
I am afraid that fuel pressure on boost is too low. Shouldnt it be around 3.7 bar?
What is stock fuel pressure?
Engine is standard 4E-FTE with standard pump, standard FPR, standard turbo CT9, 2.5" exhaust.
Edited by kotbehemot
Problem is that i don't have wideband. Only standard lambda sensor with single wire.
I have checked fuel pressure becuse during cold start: if i try to start the engine right away i have hesitating.
But when i wait a while with fuel pump on, then it starts faster.
So my shot was that pump dies , because it seems that it needs more time to build the pressure.
Also pump is whining all the time. Something like Walbro does.
I have pulled out the pump today and .. i have no idea what it is.
There is written (see picture):
4124E
12V
MADE IN JAPAN
It doesnt look like original beacuse it has "custom mounting system" :)
Is there any point changing it to genue one?
Uploaded with ImageShack.us
After shutting engine off , fuel pressure was droping slowly. But i didn't wait to see what value it will drop to.
Is it good idea to buy AFR gauge for 1V lambda sensor?
I know that reading wont be accurate , but at least i would know if its runnig rich or lean.
Only reliable way is a health check on a dyno or wideband kit, depends if a wideband kit costs more than engine rebuilds lol. I would Definately wideband that before you do some serious damage
