ady2k5 Posted October 31, 2007 Posted October 31, 2007 Hello allI had me alarm and immobiliser installed yesterday, however the main unit has been put in where the oil dip stick is, this in turn causes a problem as i was checking me oil today and as i pull the dip stick out it rubs on its way out and therefore doesn't give an accurate oil reading. The place where i had me alarm and immobiliser put in stated that there wasn't a lot of space in the engine bay and he did spend a lot of time on it in total (2 full days labour)I've opened the oil cap and it seems ok, theres oil in there and its fairly new (judging by the colour). I'm concerned me oil may be low at some point and i may not get an accurate reading.Has anybody else got this problem or any way around this.Many thanks Quote
StarletRick Posted October 31, 2007 Posted October 31, 2007 take the car back to whereever it was fitted and call then cunts. then ask them to move it. Quote
ady2k5 Posted October 31, 2007 Author Posted October 31, 2007 take the car back to whereever it was fitted and call then cunts. then ask them to move it.I phoned the guy up and he said there isn't anywhere else he can move it too, there isn't much space under there. I've had a look myself and can't see anywhere else it can go unless you could recommend something. Quote
Mart Posted October 31, 2007 Posted October 31, 2007 Could try and relocate your air filter and put it in there instead.What kind of EP are you driving? Quote
Nanglebadger Posted October 31, 2007 Posted October 31, 2007 or relocate the battery to the boot and put it there.Phil. Quote
ady2k5 Posted October 31, 2007 Author Posted October 31, 2007 Could try and relocate your air filter and put it in there instead.What kind of EP are you driving?Its an EP91 Quote
ady2k5 Posted October 31, 2007 Author Posted October 31, 2007 or relocate the battery to the boot and put it there.Phil.It would be quite inconvenient for me, can i not just get an idea of the engine oil by looking under the cap, surely if it doesn't look dry in there should be ok? Quote
Nanglebadger Posted October 31, 2007 Posted October 31, 2007 thats not a risk that i would personally take, but maybe someone with more technical know-how than myself should be along shortly and can answer that for u man.Phil. Quote
paul w Posted October 31, 2007 Posted October 31, 2007 Just how big is the damned alarm???No-one else would appear to have this problem so i'd say your fitter was a bit of a tool to say the least. ;) Quote
Glanza_Ragger Posted October 31, 2007 Posted October 31, 2007 Im assuming you mean, the alarm systems siren is installed in the engine bay ?Must be god damn loud if its getting in the way and he cant find anywhere else to fit it?Is a full size foghorn ? ;) Quote
Blue Icarian Wings Posted October 31, 2007 Posted October 31, 2007 Mines at the front left, tons of room,......... Quote
