Im painting the inside of my V and lifted one of these up to find a tiny bit of water on whatever is underneath, not alot it was just wet shall we say, just wandering what is actually under them and what i could do to stop the water getting in ? and if anyone has the part number for the grommets it would be appreciated :)
Cheers in advance !
any reply is a good one i think it may be the underside of the car and the grommet is to keep it watertight dont think water under there will do it any damage ill check in a few days and see if it dries might not be 100% dry due to condesation but ill keep an eye on it
Yeah I'm sure under them are like the edges of the fuel tank sometimes you can see parts of the rear beam, just as you say to keep it water tight, I wouldn't worry too much
I think fuel tank should be under there, im they are just to let water out of the car if you flood it. i.e drive it into a river like my brother did, as there are some in the footwells and wheel well too.
It's basically a second skin to the shell, I had water in the front footwells in this second skin. I believe it's just used as a draining thing, if it was me I would personally drill small holes through them so that the water has somewhere to go as I noticed that water tends to sit there for quite a while. Drill a hole then find a grommet to fit back over them :)
Tge water isnt on the inside of the car its underneath so must be the outside mate, you got the part number for the grommets ?
Ah those grommets go directly to the top of the fuel tank, there are others which go to a second skin.
I think the part number are these mate:
Rear seat back stop button grommet - 72646‑10020‑B1
