From what I've read, you want 3bar of fuel for 1 bar of boost, but that's just a safe amount and adjust gradually with what is said on an afr...
I wouldnt mess around if u have a plug and play. They are supposed to work well with a standard ct9 or hybrid. And fuel pump doesnt matter what it is the regualator will adjust the pressure in the rail. If i was you run it at standard pressure at even 1 bar. Also its always good to have a wideband lambda on turbo cars. You really dont want to lean out and get det.
