ryan22laird Posted November 17, 2013 Share Posted November 17, 2013 Hi guys does anyone know the standard fuel pressure regulator settings am only running 0.7 bar ? Quote Link to post Share on other sites
Sefton-EP91 Posted November 17, 2013 Share Posted November 17, 2013 if your running 0.7 bar of boost then just keep it at 2.4bar fuel pressure (standard) Quote Link to post Share on other sites
LooNy Posted November 20, 2013 Share Posted November 20, 2013 What fuel pressure for 1 bar to 1.1bar ?With ct9 turbo, walbro 255 fuel pump ? Quote Link to post Share on other sites
Kingcarr Posted November 20, 2013 Share Posted November 20, 2013 From what I've read, you want 3bar of fuel for 1 bar of boost, but that's just a safe amount and adjust gradually with what is said on an afr... Quote Link to post Share on other sites
LooNy Posted November 21, 2013 Share Posted November 21, 2013 Does the ecu matter ? I have a zep plug and play Quote Link to post Share on other sites
Kingcarr Posted November 21, 2013 Share Posted November 21, 2013 I'm not 100% to be honest, I run a blitz access... Quote Link to post Share on other sites
Turk Posted November 25, 2013 Share Posted November 25, 2013 I wouldnt mess around if u have a plug and play. They are supposed to work well with a standard ct9 or hybrid. And fuel pump doesnt matter what it is the regualator will adjust the pressure in the rail. If i was you run it at standard pressure at even 1 bar. Also its always good to have a wideband lambda on turbo cars. You really dont want to lean out and get det. Quote Link to post Share on other sites
