Adeeb1395 Posted November 26, 2013 Posted November 26, 2013 (edited) will tein coil-overs of front from nze121 corolla fit in ep82 starlet??? Edited December 28, 2013 by Adeeb1395 Quote
triple j Posted November 26, 2013 Posted November 26, 2013 No buddy, but u could make the fit with a bit of work. Quote
Adeeb1395 Posted November 26, 2013 Author Posted November 26, 2013 (edited) would you please tell me what kind of work??? is it dangerous to do? i mean would it negatively effect my handling?? Edited November 26, 2013 by Adeeb1395 Quote
triple j Posted November 26, 2013 Posted November 26, 2013 u will need to compare bolt patterns, there will be a bit of reaming out bolt holes and welding washers in, its just not that simple to say, its a proper diy job and u need to no what u are at before u toutch them. Quote
Adeeb1395 Posted December 28, 2013 Author Posted December 28, 2013 (edited) i have checked that the lower mounting bolts are same but the strut tower bolt pattern is different.here is the pics as you can see the space differences between the bolts.i am thinking that if i can use the stock plate and replace it with the tein one or i can custom made a plate for the tein....is any of this possible??? and would it hamper my handling?? Edited December 28, 2013 by Adeeb1395 Quote
Adeeb1395 Posted December 28, 2013 Author Posted December 28, 2013 here are more pics of the coilovers Quote
bucketep91 Posted December 28, 2013 Posted December 28, 2013 The fronts might fit but the rears wont Quote
Adeeb1395 Posted December 28, 2013 Author Posted December 28, 2013 i only want to use the fronts....by the way thanx mate Quote
Chris Green Posted December 28, 2013 Posted December 28, 2013 Another thing to consider is spring load / compression / extension. Personally I wouldn't bother. Have a look on the Japanese auctions, you may be able to pick some up cheap there. Quote
Rob Scott Posted December 29, 2013 Posted December 29, 2013 just buy some ep top mounts and you will be ok. i guess you just want it for lowering the car rather than handling? Quote
Adeeb1395 Posted December 29, 2013 Author Posted December 29, 2013 no i also want handling...wont i get handling with these??? Quote
Tercel-R Posted December 29, 2013 Posted December 29, 2013 They're meant for a heavier car...you'll probably be skipping over bumps instead of getting suspension movement. Could be dangerous in the wet. Quote
Rob Scott Posted December 29, 2013 Posted December 29, 2013 you need suspension to suit the car... damping, and spring rate. also to suit the type of road surface you usually drive on. Quote
