I rebuilt my engine and did this, if you're replacing the gasket because it has blown though then I'd say it needs machining to prevent it happening again.
Put a straight edge on the block deck and use a torch to shine at the bottom, if you can see light through the other side of the straight edge then get the block skimmed. Check at various different points and angles across the deck face.
