Gainzy Posted November 28, 2013 Posted November 28, 2013 Which screws are best first already disconnected the battery couldn't of picked a better time to do it haha Quote
Gainzy Posted November 28, 2013 Author Posted November 28, 2013 I can see torque screws 2 of them, I guess it's just taking them off.. Quote
DaddyDutch Posted November 28, 2013 Posted November 28, 2013 2 torque screws, then take the airbag unit out. Then 19mm iirc for the steering wheel nut, undo it slightly before giving the wheel a good pull towards you. Al. Quote
morgey Posted November 28, 2013 Posted November 28, 2013 (edited) 2 torques screws 1 on either side, they don't cone all the way out just come loose. Once loose the airbag can be removed. Then its just the 17/19mm nut in the middle. Edited November 28, 2013 by morgey Quote
Gainzy Posted November 28, 2013 Author Posted November 28, 2013 Loosened those airbag torx but airbag won't come off does it push up or slot off av been doing other things hasn't taken me this long lol Quote
morgey Posted November 28, 2013 Posted November 28, 2013 Them screws still hold it in you kinda need to pop them out a bit further then it should come out Quote
Gainzy Posted November 28, 2013 Author Posted November 28, 2013 They seem slack what a chow on gave up will have to try tomorrow when it's light, thanks for your helps Quote
_shaun_ Posted November 28, 2013 Posted November 28, 2013 Don't Take the main nut off untill the steering wheel is loose to prevent a steering wheel to the face! Is a worth while tip ha Quote
Gainzy Posted November 28, 2013 Author Posted November 28, 2013 It's almost like the torx screws are loose but tighten up there is no give in the airbag at all when both screws are loose am baffled Quote
Nick85 Posted November 28, 2013 Posted November 28, 2013 (edited) Have you followed this guide Marcus? http://www.ukstarletowners.com/topic/49722-steering-wheel-removal-and-boss-kit/ Edited November 28, 2013 by Nick85 Quote
Gainzy Posted November 28, 2013 Author Posted November 28, 2013 (edited) Ahhh ha it's that dirty gold bitch of a bolt hiding behind the plastic!! Good find there Nick Edited November 28, 2013 by Gainzy Quote
Gainzy Posted November 28, 2013 Author Posted November 28, 2013 Does anybody know if an airbag warning light will appear on the dash? Quote
morgey Posted November 28, 2013 Posted November 28, 2013 (edited) How many bolts does it have, all 4 different Toyota wheels I've removed have only had 1 torques screw on each side :sThen the 19mm holding it on?Yes it will, you can buy or make a resistor pack to fool the system into thinking its still there as for mot the light must come on then go off as normal.Think its www.dashlightremoveal.com. or something similar supply them Edited November 28, 2013 by morgey Quote
Gainzy Posted November 29, 2013 Author Posted November 29, 2013 (edited) Am gunna double check tomorrow I didn't see a plastic bit under the wheel.. can the airbag warning light be removed like the seatbelt one? Just am changing the bulbs once the wheel is off Edited November 29, 2013 by Gainzy Quote
Nick85 Posted November 29, 2013 Posted November 29, 2013 Ahhh ha it's that dirty gold bitch of a bolt hiding behind the plastic!! Good find there Nick 5 minute search for me on here. 3 hour search for you in the car hahaha Quote
Gainzy Posted November 29, 2013 Author Posted November 29, 2013 5 minute search for me on here. 3 hour search for you in the car hahahaI will let you know how successful it's been tomorrow I can't remember seeing a grey plastic case might aswell pre book an ambulance lol Quote
Gainzy Posted November 29, 2013 Author Posted November 29, 2013 Got it off we hey after a good wrestle now I need to know which bulbs in the back are for the airbag warning light and am pretty sure the seatbelt is the bottom right... Quote
Gainzy Posted November 29, 2013 Author Posted November 29, 2013 Can't even see an airbag warning light Quote
Zeldoz Posted November 29, 2013 Posted November 29, 2013 My seatbelt light is flashing constantly.. Does this mean i can unplug the farking bulb! I dont have the sensor under my seat so it thinks im not wearing i! Quote
Gainzy Posted November 29, 2013 Author Posted November 29, 2013 My seatbelt light is flashing constantly.. Does this mean i can unplug the farking bulb! I dont have the sensor under my seat so it thinks im not wearing i!Yes you can indeed, does anyone know about fitting the boss around these Quote
Gainzy Posted November 29, 2013 Author Posted November 29, 2013 Also this connector does not fit onto here for the horn am sick as fook Quote
Gainzy Posted November 29, 2013 Author Posted November 29, 2013 Ok so I removed the circular thing with yellow writing on that made the boss fit easy enough Quote
Gainzy Posted November 29, 2013 Author Posted November 29, 2013 (edited) Over all there was only two torx screws after unscrewing them the airbag lifted up from the bottom, disconnected the yellow clip but there is also a blue wire, is that for the horn? Would that wire into the red wire on my boss to make the earth? Edited November 29, 2013 by Gainzy Quote
